02-11-2013, 09:09 PM #1
- Jan 2013
- 969
Giving up stem thermometers forever to check temp rise and drop....
....so I have been researching and found a Fluke dual port differential reading thermometer for over four hundred dollars...but made in China.
That was the deal breaker.
I want a good thermometer that does not need to be calibrated every time I use it.
Curious as to what other techs are buying?
02-11-2013, 09:49 PM #2
- Mar 2006
- 949
Use the fieldpiece dual temp. Never failed me and can field calibrate. Had for over a year now i guess and use almost daily
02-11-2013, 09:54 PM #3
- Jan 2008
- LEHIGH VALLEY, PA
- 137
i use the field piece daily , invaluable for my service work , can be heavy on batteries as it is easily switched on in error . st4 i think
02-12-2013, 07:19 PM #4
- Nov 2011
- Charleston, Wv.
- 686
i use the FP.....but with any K-type, you gotta calibrate every few months or so.
02-12-2013, 07:51 PM #5
Professional Member*
- May 2006
- Austin, Texas
- 185
For less than $50, you can get two FP folding probe thermometers. For delta Ts, it only matters if they are calibrated to each other. Been carrying two around in my bag for years. I have more expensive meters for actual temperatures. When I enter the home I lay both probes across the thermostat while talking with customer. I have the checked their thermostat and my thermometers.
