Results 1 to 13 of 19
    Nov 2008
    DFW,TX
    standing wall heater, milivolt/microamp volt readings?
    ok so i dont work on a lot of these but on a service call for no heat,
    The pilot lights and stays lit, it puts out voltage to gas valve at around 105Ua, checked the t-stat and it works and i jumped it out just in case and no gas will come out of valve and I also cleaned the the thermocouple and checked all limits.. all seem to be working yet no gas coming from valve.
    So two questions how many micro amps/volts does it take to open the valve and what is the reading supposed to be coming from a flame generated sensor?
    Im pretty sure its the gas valve but just double checking..thanks
    Jul 2010
    nebraska
    Good thermocouple should put out around 25 millivolts,no lower than 20. Meter can't be set on microamps to check thermocouples.
    Nov 2009
    Simcoe, ON Canada
    What brand of gas valve is it? I will post a couple of troubleshooting tips tomorrow.
    Does it have a thermocouple and thermopile or just one of the two?
    If you pm me the brand i may be able to give you better suggestions.
    I install and service wall heaters quite often.
    Nov 2008
    Bristol Va.
    are you talking about a thermocouple or a thermopile? above post is good for thermocouple but thermopile is around 750 millivolts. You can tell it is a thermopile as it will be larger than a thermocouple.
    dogboy
    Nov 2008
    DFW,TX
    Quote Originally Posted by DOGBOY View Post
    dogboy
    i guess its a thermopile because IT GENERATES THE MILLIVOLTS needed to power the tstat and gas valve on a wall heater.. how do you measure that to make sure its enough.. i had 105 microamps so it was putting out volts so where do i take the reading and whats the normal range?
    Nov 2008
    Bristol Va.
    Quote Originally Posted by acguytx View Post
    AS stated above generally they put out 750 millivolts. there may be different outputs but the ones I used were 750mv. You got 105 millivolts. So I guess you check it the way you did, with the meter across the thermopile. Microamps has nothing to do with it.
    look at the second page.
    http://www.robertshawtstats.com/spaw...oltSystems.pdf
    dogboy
    Nov 2008
    DFW,TX
    dogboy
    good link, thanks man..
    BTW im not sure i was using my meter correctly but i was checking with my FP SC 56 meter with the dial select on the uA setting and that where i measure the 105 at across the first two terminals on the block while flame pilot was lit.. what setting on my meter do i use to measure milivolts ?
    Nov 2008
    Bristol Va.
    I would say vdc as your meter should auto range down to millivolts. Are you a technician? as this is pretty basic.
    dogboy
    Oct 2011
    Las Vegas, NV
    On the sc56, set your meter to volts. Then, press the button to the far left (square with a circle around it) until mV is displayed on the screen. That will read millivolts at that point.
    Sent from my Evo 3D CDMA using Tapatalk 2
    Athens, Ohio
    If it is a White Rogers thermopile throw it away and get a Honeywell. I've had so many bad White Rogers t'stats and other parts that I refuse to buy them any more.
    May 2012
    Upper Michigan
    I used to have a pic of me checking millivolts on my phone, I had to delete it because I was in my speedo but anyways the two Leads off the ppile you hook up to them and its vdc, my hs36 just ranges itself to millivolts. If you jump the stat wires at the gas valve and it works you can tell if the valve is bad or good.
    Sep 2003
    One thing to check if the millivolts check out would be a spiderweb in the burner orifice
    The love to get in there and spin a web
    clean the pilot and replace the thermopile
    Go Trump
