Results 14 to 26 of 33
    Feb 2013
    The tech told me from the start that he's never seen a unit set up like that in 25 years.
    The flame sensor is on the right side next to the gas inlet and the ignitor is on the left side by the last burner.
    NCstate- Can someone confirm that this set up is right? Do you have access to a diagram?
    He will be back today to install a OEM ignitor
    I do know that the tech replaced the ignitor per the location of the bad one. So I'm guessing there is only 1 location that it could go.
    Atlanta GA area
    Quote Originally Posted by aco2451 View Post
    IMO you are on a good track there... Here is a suggestion:
    Give the tech access to your computer... he probably can find the info he needs.
    If indeed the flame sensor and ignitor have been switched... that would account for the pop at ignition.
    Tuff to diagnose things like this without being there or at least looking at a picture.
    GA-HVAC-Tech
    Northeast Ohio
    Most likely the OEM ignitor will fix the issue.
    DEM
    Feb 2013
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Athens, Ohio
    +1 for ignitor not positioned properly. I encounter that regularly when installing a universal ignitor. Once the position is right the problem is solved.
    I am curious about the sensor and ignitor location. All that I have seen are set up with the ignitor by the first burner and the sensor at the opposite end. However don't all burners get gas at the same time? How would reversing the parts change it.
    Feb 2013
    Feb 2013
    One thing I have noticed that all 4 burners ignite a the same time. not one at a time.
    The tech looked over the burners and said that they looked good.
    I tried to take a video of what it's doing. http://<a href="http://youtu.be/NFmw...Fmw2FycMLQ</a>
    *note the video was taken after the first ignitor was installed and intake pipe still intact.
    Athens, Ohio
    The link does not work.
    Feb 2013
    Try this.
    Athens, Ohio
    I can view the video now. And it just sunk in for me that this is a sealed, two-pipe system. The tech needs to check draft, gas pressure and put a combustion analyzer on the system.
    What is the Btu input of the furnace and what size are the PVC vent pipes?
    You need a THOROUGH technician, not just a parts changer.
    Feb 2013
    Gas Pressure was adjusted to 3.5, was at 2.1 when he first check it out thinking the pressure was too high.
    I'm not sure on the BTU input I can check that when I get home.
    the PVC pipes are I would guess 4" ID
    n.e.techjim, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    May have only started for after they changed out the HSI/ignitor. But it was having problems before you bought the house. Thats why the gas pressure was turned down to just over 2".
