Thread: Koolsurge
    Jun 2007
    Williamsport, PA
    Koolsurge
    I have a rack with this controler on it, I dont think it is working correctly. Does anyone have any information on this.
    Jul 2000
    Treasure Coast/Florida
    As I recall, Hussmann's Koolsurge showed up in the 1980's with the Plus System racks. It was supposed to work like Hill's Attron system to control either flow though or surge receiver operation for low ambients. Hussmann later came up with Autosurge for the SuperPlus.
    I may still have some old info on Koolsurge at the shop. I'll have to dig for it.
    Jun 2007
    Williamsport, PA
    It does not look like it is worth the time, effort or cost to get working. What was its function? I am sure the
    rack would run fine without it.
    Jun 2007
    Williamsport, PA
    I looked up the Attron on this site, there was alot of good information on them. I think what I have is different in that the drop leg is not attached to the liquid header but goes into the top of the reciever,I will look when I go back out. If the drop leg does go into the reciever then I would not need this controler to pressurize the reciever to force the refrigerant out. Am I thinking right.
    Jul 2000
    For what it's worth, I scanned the Koolsurge info I have. The PDF file is too big to attach, so I uploaded it to Dropbox:
    https://dl.dropbox.com/u/105545497/H...surge_1982.pdf
    I don't have any first-hand knowledge of how this setup is supposed to work. I hope this helps.
    Jun 2007
    Williamsport, PA
    Thank you Ice for your help.
