Results 14 to 26 of 33
    Jan 2010
    I thought I already responded to this thread.
    Jul 2005
    [QUOTE=VTP99;15202371]
    Quote Originally Posted by hvacrmedic View Post
    I also tried a set of these breifly.
    What happened ?
    They went out of calibration, couldn't even be zeroed. I shipped them to Doug Lockhart so he could look them over. He cut his finger on one of them and promptly smashed them with a sledge hammer. It's a long story.
    Jan 2010
    [QUOTE=hvacrmedic;15202431]
    Thanks for reminding me not to buy one
    Haha. Me too.
    Sent from my SGH-T999 using Tapatalk 2
    Jan 2013
    Salisbury, Maryland
    I use them ALL the time. Whenever I'm doing maintenance I use those first, and then I'll whip out the digital's if I need to. I use BV on mine and also carry around a 6" hose incase I need to get in a tight space....perfect example being the retarded way Rheem installs their valves on some ODU's. I'm thinkin about getting another set and calibrate that for a different common reefer just to have them. United Reefer should have everything you need to rig this up, at least the one over my way does.
    Aug 2011
    York, PA
    I'm confused..... I've been using a guage set up like this for over 15 yrs....... I use it to check seal pressures, and to verify transducer readings on chillers........ am I missing something special about the one in the picture that was posted?
    Jan 2013
    Thanks guys.
    I got the YJs from HVCRtools.
    The advice on using a the ball valve hose was a great suggestion.
    Mar 2009
    Mid-Mo
    Doesn't sound like too long of a story!!!
    I have a set of these and I find them very useful for all the reasons everyone uses them for....
    Dry as a bone Tucson
    Mine are Marsh's on 90* quick connects.
    I use mine mostly to verify proper compressor phasing at start up.
    Watchman Nee
    Jul 2005
    [QUOTE=ryan1088;15204071]
    LOL! Well the "rest of the story" is long. Let's just say that Doug isn't very fond of Ritchie Engineering Company, Inc.
    Oct 2010
    AZ
    Quote Originally Posted by Can-Gas View Post
    We were just talking about these the other day, or a homemade version at least. I like the idea of them, but I think the rigidity of it would cause problems attaching it to some units. Actually, I should correct that by saying some "installs"....it's not the units fault.
    I use one and it is true that you can have clearance issues. And sometimes it is the unit's fault. On some models, you have the schraeder on the back side of the service valve and it doesn't fit because of other factory stuff in the way. They are not flexible at all. In these cases, I have one of those really short hose extensions with a built-in ball valve that is meant to go on the end of a regular hose. It has a male end and a female end and takes care of the problem. If you make one, just find a fitting to attach the gauge thread to that hose extension thread because you will have clearance issues with the other setup.
    Nov 2011
    East Side
    I use them to Pm equipment all the time. minimizes removing a few ounces of refrigerant each PM....
