Page 3 of 3 FirstFirst 123
Results 27 to 33 of 33
  1. #27
    Jun 2002
    south jersey
    I have a couple like that mounted on thumbscrew type core depressors.
    http://www.cdvalve.com/product-categ.../cd2070/10-169
    I mostly use them for getting oil pressure readings on simi-hermetic compressors.
    The depressor lets me open the valve after connecting the gauge, and close it before removing it, so there is almost no mess made.
    I did not know these thumb screw depressors existed. I think I may have to get a few. Any common suppliers carrying them or are they only online?
  2. #28
    On the thumb screw ones release the pressure on your hose connection otherwise your oring blows out
  3. #29
    Nov 2010
    MN
    Quote Originally Posted by jnsrose View Post
    C & D makes them.
  4. #30
    I get them at Johnstone supply.
    Part #H24-849.
    And watch when you remove them, as already mentioned, the little o-ring can blow out real easy (they include spares).
  5. #31
    I had one many years ago but was not too impressed, constantly adj. I think I got mine at Johnstones Supply.
  6. #32
    Quote Originally Posted by PMARS2345 View Post
    C & D makes them.
    Quote Originally Posted by 76olds View Post
    Part #H24-849.
    The ones I linked in my previous post don't have the o-ring blowout issue, because the valve can be back seated.
    After disconnecting, you can crack the valve open slightly to slowly release the pressure held in the tube/hose.
    They are not the same ones 76olds gave a Johnstone part number for.
    http://www.hvacr-tools.com/product/c...or-back-seated
    RSES Certificate Member
    RSES-SWRA President
  7. #33
    Mar 2001
    Ilwaco, Washington
    Used em for years on critically charged cascade systems (blood and tissue freezers) & ice machines. They're in my Veto.
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
