    Aug 2012
    Iraq
    marshal heat pump split defrost problem
    hi
    i have marshal 2 ton split unit r22
    in heating mode it work perfectly
    the outdoor fan never stop working
    then discharge temp is 110 c
    suction is 55 c
    13 amp current
    compressor is not hot
    i set indoor unit to 32 c
    but the outoodr fan never stop spinning
    and water is continue flow from outdoor unit
    i suspect the indoor sensor on pipes may be not fixed correctly so i unpluged it then plugged it
    so the outdoor fan stopped work and compressor kept running
    after one day
    i turned on the split so
    the fan and compressor kept working never stoped until the room temp is reached 32 c
    so both comp and fan stopped
    so what the cause of the problem
    Mount Airy, MD
    Thread relocated to "Tech to Tech"
    Aug 2012
    Iraq
    up
    Aug 2012
    Iraq
    the problem was fixed
    that happened because of bad indoor unit pipe thermistor
