Results 1 to 13 of 19
    Aug 2012
    Iraq
    purging and pressuring ac with n2
    hi every one
    i want to use n2 in purging and testing ac for leaks
    and first time to me
    my q are
    1_ what precautions i must make in care when use n2 in purging etc....
    2_ which type of n2 i must use
    because in iraq we have pure n2 only but some experts adviced me to use impure n2 cylinder which contain 90% n2 and 10% oil because its best than pure n2 in purging and testing
    Apr 2010
    NC Sandhills
    This is not a do it your self site but I will give basic safety information. The main precaution is use a pressure regulator that is in good shape, has a clean over pressure release valve and check hoses for cuts or tears and max working pressure! Max pressure depends on system and equipment, read labels. Wear safety glasses. Use pure nitrogen only. Bad gas and oil can contaminate the system. Unless they meant to add a little refrigerant so an electronic leak finder can also be used.
    Mount Airy, MD
    Thread relocated to "Tech to Tech"
    Use pure/dry nitrogen. You don't want to be adding oil to a refrigeration system when you flow or pressure test with nitrogen.
    Apr 2001
    MINN
    Are you serving in the Military
    Aug 2012
    Iraq
    Quote Originally Posted by beb View Post
    i dont understand
    Aug 2012
    Iraq
    thanx to every one for help
    now my question
    can i use the same type o2 gas regulater with n2 cylinder
    i use this type with o2 cylinder
    Aug 2012
    Iraq
    up
    Quote Originally Posted by kefah View Post
    now my question
    You would use a SIMILAR regulator, but not the SAME regulator.
    The cylinder connection is different.
    Aug 2012
    Iraq
    no the cylinder connection is the same
    Not on my cylinders.
    There really isn't a reason that an oxygen regulator wouldn't work on a nitrogen tank and vice-versa.
    I would be very careful about crossing them, though, because oxygen can be nasty stuff. If even a tiny amount of oil is present, you could see an explosion.
    Aug 2012
    Iraq
    thank u for help
    Oct 2012
    Smallville
    Check data plate for test pressures. It will have low and high side pressures. Don't go any higher than the low side pressure.
