Results 1 to 6 of 6
    Feb 2013
    Delta ORCAview question(s)
    Hello,
    Let me first start by saying I am contracted IT support person at a distribution center and not an HVAC specialist. I have been asked to assist with a particular issue. With that being said here is the scenario. In the sprinkler room there is a PC that has ORCAview 3.33 installed Build (816). There is no longer any support for this PC or the software according to the site. The PC in the sprinkler room works perfectly. What the site would like is to have the same software installed on a 2nd PC located at the main security desk as they will be better able to monitor the readings. There does not appear to be an installation CD anywhere, so part of the request is can the software be downloaded and installed directly onto the 2nd PC? In addition, would the 2nd PC require a dongle? The original PC does appear to have a USB Dongle. Next, supposing that the software can be installed and the dongle issue is worked out one way or the other, is it just a matter of running the software and the proper readings will come up, or would there be some configuration after install in order to allow it to view the proper readings?
    I am ready to do as much investigation as required to set this up and appreciate any help that I am offered.
    Regards,
    Sam
    Sep 2009
    Michigan
    Get with the local Delta Rep.
    Dec 2006
    What? Who? Where?
    Quote Originally Posted by sucosam View Post
    Hello,
    Let me first start by saying I am contracted IT support person at a distribution center and not an HVAC specialist. I have been asked to assist with a particular issue. With that being said here is the scenario. In the sprinkler room there is a PC that has ORCAview 3.33 installed Build (816). There is no longer any support for this PC or the software according to the site. The PC in the sprinkler room works perfectly. What the site would like is to have the same software installed on a 2nd PC located at the main security desk as they will be better able to monitor the readings. There does not appear to be an installation CD anywhere, so part of the request is can the software be downloaded (NO) and installed directly onto the 2nd PC (YES with CD)? In addition, would the 2nd PC require a dongle (YES)? The original PC does appear to have a USB Dongle. Next, supposing that the software can be installed and the dongle issue is worked out one way or the other, is it just a matter of running the software and the proper readings will come up (YES, although you will have to transfer the graphics from the original PC ), or would there be some configuration (Minor config of IP settings) after install in order to allow it to view the proper readings?
    Regards,
    Sam
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Breslau, Ontario
    Hi there,
    I would contact your local Delta rep, config can be tricky since you will need to address your OWS, transfer graphics etc...
    Feb 2013
    Thank you for the information. I believe that this has answered my questions and gives me a direction in which to proceed. Many thanks
    Jun 2001
    Michigan
    adhoc 2nd pc
