    Niagara AX issue - Connecting to local station
    Hey guys,
    We have recently taken over a site with two Vykon JACE 2 controllers. They are using the local station to pass Global points, however the station has fallen over.
    Error log when trying to connect:
    javax.baja.naming.UnresolvedException: fox:
    at com.tridium.fox.sys.BFoxScheme.resolve(BFoxScheme. java:94)
    at javax.baja.naming.BOrd.resolve(BOrd.java:255)
    at javax.baja.naming.BOrd.resolve(BOrd.java:209)
    at com.tridium.workbench.shell.BNiagaraWbShell.resolv e(BNiagaraWbShell.java:468)
    at com.tridium.workbench.shell.NHyperlinkInfo.resolve (NHyperlinkInfo.java:235)
    at com.tridium.workbench.shell.NHyperlinkInfo.hyperli nk(NHyperlinkInfo.java:88)
    at com.tridium.workbench.shell.BNiagaraWbShell.doHype rlink(BNiagaraWbShell.java:374)
    at com.tridium.workbench.shell.BNiagaraWbShell.hyperl ink(BNiagaraWbShell.java:332)
    at javax.baja.workbench.nav.tree.NavTreeController.no deDoubleClicked(NavTreeController.java:74)
    at javax.baja.ui.tree.TreeController.mousePressed(Tre eController.java:227)
    at javax.baja.ui.tree.BTree.mousePressed(BTree.java:5 76)
    at javax.baja.ui.BWidget.fireMouseEvent(BWidget.java: 1134)
    at com.tridium.ui.awt.MouseManager.fire(MouseManager. java:305)
    at com.tridium.ui.awt.MouseManager.fire(MouseManager. java:279)
    at com.tridium.ui.awt.MouseManager.pressed(MouseManag er.java:106)
    at com.tridium.ui.awt.MouseManager.process(MouseManag er.java:87)
    at com.tridium.ui.awt.AwtShellManager.processMouseEve nt(AwtShellManager.java:512)
    at java.awt.Component.processEvent(Unknown Source)
    at java.awt.Container.processEvent(Unknown Source)
    java.net.ConnectException: Connection refused: connect
    at java.net.PlainSocketImpl.socketConnect(Native Method)
    at java.net.PlainSocketImpl.doConnect(Unknown Source)
    at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
    at java.net.PlainSocketImpl.connect(Unknown Source)
    at java.net.Socket.connect(Unknown Source)
    at sun.reflect.GeneratedMethodAccessor3.invoke(Unknow n Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Un known Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at javax.baja.naming.BIpHost$WorkaroundSocketFactory. open(BIpHost.java:422)
    at javax.baja.naming.BIpHost.openSocket(BIpHost.java: 284)
    at com.tridium.fox.sys.BFoxClientConnection.connect(B FoxClientConnection.java:497)
    at com.tridium.fox.sys.BFoxSession.connect(BFoxSessio n.java:247)
    at com.tridium.fox.sys.BFoxScheme.resolve(BFoxScheme. java:81)
    We have searched this site and taken on some of the recommendations. We have tried to run the Daemon platform and it installed and started okay. The issue is still present.
    We're under a bit of urgency as one of the Global points it passes is for the Cooling Call, so no Chiller.
    Any help is much appreciated.
    - Adrian
    Forgot to mention: Ports are not blocked.
    Jan 2005
    "at com.tridium.workbench.shell.BNiagaraWbShell.doHype rlink(BNiagaraWbShell.java:374)"
    Looks like its in shell mode. Check the serial shell jumper.
    "It's always controls"
    Jan 2002
    Fort Worth\Dallas, Texas
    I don't think it is in shell mode. I had this same problem before and never figured out what caused it. I assumed it was something network related since it cleared on it's own.
    https://www.niagara-central.com/ord?...onThread/11827
    Go Rangers!
    San Diego, CA
    The connection refused tells me it's likely an issue with the fox port not being open, or the incorrect port # being used.
    If it were a version mismatch, you'd see "Access Denied" or if incorrect credentials, you'd see "Authentication Failed"
    Lane's post looks similar, but was just a connection timeout issue.
    Jan 2017
    Hi Adrian,
    Would you mind sharing code used for making connection to Niagara or point to any reference document.
    I am also facing similar issues.
