Results 1 to 2 of 2
    Feb 2013
    Question Carrier MXA Fan Issue
    Carrier 58MXA. Circuit board was recently replaced with aftermarket ICM unit by local HVAC contractor. Since board has been replaced, the fan is not functioning properly. When thermostat ends call for heat, the fan shuts off immediately instead of doing a 90 sec delay. It only does this during probably 1 out of every 4 operation cycles. I have observed the furnace during operation and when it does have fan problem, the status LED turns off for a brief second, like the power to the board has been cut. LED is not flashing any codes. The tech who installed board has already been back once to try to fix problem. He somehow determined that pressure switch was causing problem. Pressure switch was replaced but fan problem is still happening. I guess the real question is what is causing power to board to cut out when call for heat ends. Any ideas?
    Feb 2013
    So the guy who asks if he can substitute a match for an HSI gets two pages of replies but I get nothing?
    Anyway, the tech came back for a third time and replaced the ICM board with an OE Carrier board. Problem seems to be fixed.
