Results 14 to 22 of 22
Thread: Traulsen, TXV's but no receiver
02-11-2013, 08:04 AM #14
- Jul 2011
- Lehigh Valley, PA
- 225
02-11-2013, 08:44 AM #15
- Feb 2004
- Madison, WI
- 253
I think some "receiver" capacity is in the design of the condenser. Or the condenser can hold the entire refrigerant charge. If memory serves I've serviced a few freezers with TXV's and no receiver that still had a liquid valve that allowed you to pump it down for service procedures. The condensers were able to hold the entire system charge. Ditto with A/C units.
02-11-2013, 08:51 AM #16
- Apr 2010
- San Diego, CA
- 105
They make refrigerators for a market that is saturated with cheap equipment, built with corner cutting in mind. Refrigerant is expensive, use less and you save money. Even with a receiver they would put in just enough for it to work, so might as well cut the receiver out and save that coin too.
Just my opinion. Can't imagine that anything other than cost drives the use of critical charge systems with TXVs.
02-11-2013, 09:19 AM #17
Professional Member*
- Oct 2009
- Raleigh, NC
- 435
There is no need for a receiver in a system where the ambient is controlled and the load doesn't vary much.
Sent from my ADR6350 using Tapatalk 2
02-11-2013, 11:01 AM #18
The receiver is not for pump down nessisarily. It's needed when additional flooding charge is required for low ambient operation. If ambient is controlled, as pointed out earlier, the cond coil can hold the entire charge during pump down. A lot of your reach in equipment may not have or need a receiver. Self contained reach in equipment any way. Remotes may need them even if cond is in controlled ambient depending on lineset.
02-11-2013, 05:48 PM #19
- Sep 2007
- NH
- 916
02-11-2013, 05:53 PM #20
- Jun 2011
- wi
- 12
02-11-2013, 07:41 PM #21
- Jan 2010
- 4,410
02-11-2013, 08:53 PM #22
- Jun 2012
- Tenn
- 94
Depends on how the TXV sits relative to the condensor, and what the capacity is. Plenty of low charge systems have no reciever. Like someone mentioned earlier, many AC's don't have recievers. As long as there is a good supply of liquid refrigerant consistantly between the TXV and the condenser, it will still function well.
