Results 1 to 2 of 2
    Nov 2012
    Slip stream boiler sizing for freeze protection?
    Need help sizing a slip stream boiler that will be used to provide freeze protection in a ground-source geo loop. I know the design load and flow rate of the field, fluid will be 100% water, Midwest location and no part of the loop piping is exposed above ground. Is there a formula or rule of thumb that applies here?
    Jun 2013
    NORTHERN
    Condensing boiler success with IBC and ask for US rep JP A on line ibc boilers.
    share heat of absorption required at ~ 35 ew to your system (37 highest) that you can obtain BTUH from your OEM.
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
