Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 75
  1. #40
    Jun 2001
    Michigan
    I was thinking that if it were in split, when not in HR, thats my 40%. Say it was not split and no HR. Correctly done with parallel I would expect to see 0% in normal since I see 0% in HR = Undercharged.
    I am assuming correct application of parallel. That they did not do a parallel as a series.
    That was my theory. And just needs to be proved.
    To answer Pat, to go high head on HR with out Blower on, then you know this makes Matt's theory. If it were in true parallel you ought to expect to go high with no blower (condenser fan).
    I dunno. I hope we get updates on this guy.
  2. #41
    Jan 2006
    DFW Metroplex
    So you're saying it's worked this way for a hundred years and only now has someone taken the time to figure it out? Sounds familiar...
    "The problem is the average person isn’t tuned in to lifelong learning, or going to seminars and so forth. If the information is not on television, and it’s not in the movies they watch, and it’s not in the few books that they buy, they don’t get it" - Jack Canfield
  3. #42
    Jan 2010
    Sea to Sky
    Quote Originally Posted by Dowadudda View Post
    0% in HR with blower on. 20% in HR with blower off. 40% in air cooled and no HR.
    It is equipped with split. We don't know if it was in split. I thought it was first read.
    I see what your saying Matt.
    So if I understand this correctly, liquid refrigerant is logging in the HR, which gets worse when the blower turns on, due to increased airflow across the HR.
  4. #43
    Sep 2010
    Quote Originally Posted by markettech View Post
    So, juice the rack up to 80% receiver level and let 'er fly...........
    LOL I'd love to but I know that's never going to happen as we pay for gas and its 22.
    Wow, thanks for so many replies. Just got back from running a few calls.
    And I'm positive that it never goes into split while in HR. It is controlled by ambient temp sensor. I'm still learning ALOT about these stores so I'm not even sure if any are set to do this. I'm used to wally world's simple hot water reclaim setup.
    I think I'm going to have to find the book again for the RMCC to see if it will open the other condenser if pressure becomes too high while in split for reclaim.
  5. #44
    florida
    I really don't think its split that far South and knowing the main chain down here.
    Educational forums are open.
  6. #45
    California
    Sounds like someone has done something to the other systems.
    Quote Originally Posted by steelsparky View Post
    I starting to lean towards the heat reclaim coil is too large and with the A/C on the liquid is staying in the reclaim coil or condenser. Run's like a 2 1/8" line to and from. Someone has cut come circuits out of the other reclaim coil on the other McQuay.
    Someone cut circuits out of the other reclaim coil, making it work for series operation.
  7. #46
    Jun 2001
    Michigan
    I really am suspect of the split myself. And this is my stubbornness. How many guys know to jagoof the controller to keep it in split to keep liquid up and not fix it?
    I don't know if I am on something, Pat is on something or Matt is on the issue. But I do know to comprehend this and all understand each others speculation, just tells me I keep good smart company.
  8. #47
    Jun 2001
    Michigan
    fast recovery????????????????????
  9. #48
    Jun 2001
    Michigan
    crackertech, the man says it's equipped with split. I am going by what he says.
  10. #49
    Sep 2010
    Man you wouldn't believe some of the stuff I've found since I've taken these stores over
  11. #50
    Jun 2001
    Michigan
    I can tell you this and Pat will back me up on this. We had 65 stores here, all lead pumps, if not more than lead pumps, wired and dipswitch wrong for unloading. So, controller asking to load up, and unloading. It does not take mych to control something wrong, and then the cheaters who don't want to fix leaks.
    I am telling ya. If it were fugged up capacity wise, (parallel capacity done in series) not saying it's not possible, but it's always my last blame.
  12. #51
    florida
    If he works for the major chain down here than there is no split that far down unless it's a real old store.Then it's still not likely.
  13. #52
    California
    try us
    everyone here has seen a lot!
