Results 14 to 20 of 20
    Feb 2013
    I was hopeful when I had the first contractor out that his estimate would be cheap enough that I could hire him to do the whole thing, maybe buy the equipment myself but him do all the work. When I got his bid I realized that was not going to happen. However I realized that doing as much as I could myself I was going to need some guidance (how many ducts where what size ect.) So I called another contractor and just ask him if he would be willing to "design" the system for me and hook it up. He agreed to do that but said that he like a shot at selling me the duct work also. So like I said earlier I am going to buy the duct work from him and he is going to hook up the system. I bought the system and will install the duct work.
    Jun 2006
    Richmond, VA
    Quote Originally Posted by slad35 View Post
    If your "designer" walks thru your house and says you need 2 outlets in this room, 1 in here, 3 in here.......and if you ask him how he sizes the ducts and he says "I use .1 static".....you are doomed. Especially since the system you bought is particularly fussy about the duct it is hooked up to.
    "Decidedly Superior in a twisted pathetic way".....
    Altmar, New York, United States
    that contractor is in for a rude awakining. this usualy does not work out. it looks good on paper. how is he going to design it? is he doing a heatload or can he get it right without one? is he that desperate for work?
    Feb 2013
    He is a very reputable contractor in our area. He sells arcoaire. Why would duct work be different for a certain system if tonnage is the same? What do you mean that system is particularly fussy about duct work it is hooked up to? What should I do?
    Jun 2006
    Richmond, VA
    1. So this contractor has never installed an evolution system? Bryant won't even sell them to their dealers without taking a class and passing a test.
    2. I hope the equipment does have a warranty....the parts on that stuff is rather expensive.
    3. It is very nice equipment and has many design features to protect itself....One of them is called high static shutdown...if the duct is too restrictive....it shuts down or if you are lucky stages down and you will have a 3 ton that only runs at 2 tons.
    4. There is a proper way as stated before....Manual J load calculation, Manual D duct design, Manual T Air distribution to select the correct registers for spread/throw. Manual S for Equipment size selection to pick the correctly sized unit from manual J....However you kind of threw that out the window since you already bought the equipment
    Feb 2013
    Do you think I should have a Bryant dealer hook up the system? What about designing
    the duct work?
    the duct work?
    you will want a good duct design done to insure the complete system works to it's full potential. after all, you are spending a good chunk for the system why not just spend a little more and make sure it is right. you will be much hapier if you do. and it will run at it highest efficiancy. i recommend a qualified bryant dealer. they make you take a test for a reason. good luck
