Results 1 to 9 of 9
Thread: Siemens PXC3...
    Jan 2013
    Siemens PXC3...
    hello
    I have to schedule a PXC3, but xwork plus 4 when I choose the type of contrlorre I do not compare. What software should I use?
    Apr 2008
    UK
    By Schedule do you mean install/configure and that you cant find it as a device in the drop down menu?
    I believe you need XWorks V5. They also have a stand alone program to set it up as well but you can't do it just direct froma web page, something about security issues, though I think its just an XMLfile that gets downloaded.
    Don't be a stupid dwarf. It's not big and it's not clever!
    Jan 2013
    hello,
    I found this on the Internet
    https://www.siemens.be/cmc/upload/cm...missioning.pdf
    This is the software for programming?
    I as I understand the PXC3 are not freely programmable but can be configured as RXC, right?
    Apr 2008
    UK
    Theres a number of flavours of PXC3's, there the PXC3.L which is a BACNet/LON to BACNet/UDP/IP router, the PXC3.M which is the same as PXC3.L but with added MS/TP connections, and I think there is a PXC3.W100 which is a stand alone web server dishing up HTML5 web pages.
    What are you trying to do?
    Jan 2013
    hello
    I buy on the internet a PXC3.72A.
    I would programarlo to manage heating, lights and blinds,but with
    with the 'xwork v4 can not do nulla.Volevo know if the software for these controllers is not free, and if you like to buy it is called
    Apr 2008
    UK
    Sorry, was getting my part numbers mixed up. I stated PXC3.L but I was actually talking about a PXG3.L
    The device you are talking about is part of their Total Room Automation range and I believe you need a licensed copy of the software to work with it. I know it comes on the install disks of V5 XWorks and I expect it uses the same licensing as this. Its yet to be released in the UK so will know more in a few weeks.
    Aug 2014
    Smile PX3.Exx
    Hi,
    For PXC3.Exxx, you will need the XWP plus V5 to be able to programm it.
    The PXC.Exx is a TRA (Total room automation device).
    Under XWP V5, you will have a new programmation tool calls "TIA portail".
    Using this tool you will be able to programm FREELY your device. -A really advantage compared to the RXB or RXC family-.
    An other advantage of this tool: TXIO, Pl-Link and DALI bus are communicative.
    Have fun!
    Mar 2013
    Hello, has the PXC3.L been released in the UK as yet?
    Aug 2014
    Quote Originally Posted by goochr96 View Post
    Hi, I do not know in UK. But in Switzerland, Belgium and other countries, this device has been released since a while.
Comfortech365 Virtual Event
