Results 1 to 8 of 8
    Lennox G60UHV-36B-090
    Any idea as to why this furnace would need the flame sensor cleaned or replaced every month?
    Nov 2012
    Is the furnace dirty and sucking in a lot of dust? Is there something in the air that could be burning to it? What are you using to clean it with? Don't use sand paper. I just use a small wire brush.
    as other may chime in on, it may be a poor ground.
    flame sense happens with/in the ground path.
    if it is truly monthly, I would have tried a new flame sensor after the second trip. also, verified ground and maybe new board.
    I highly doubt it needs a new flame senor, it is probably the method you are using to clean it. Use low abrasive steel wool. (Not sand paper) Also if the furnace is in a laundry room that could be your issue, lent and silicone base fabric softener in the air will coat the sensor. Check for voltage across "c" and neutral, voltage should be 0 if you have a good ground. Flame sensors don't go bad , It is simply a metal rod insulated with porcelain. A clothes hanger could be a flame sensor if you could mount it without grounding it.
    Jan 2011
    Highland Park, CA
    Check the grounding. From the receptacle through your furnace/board/burners. Must have good earth ground.
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by joeblo View Post
    A wire brush is still too abrasive. I use a dry shop rag. If that doesn't raise the Reading then you probably have other factors, dirty burner face, ground, gas pressure...
    Lancaster PA
    Quote Originally Posted by Dean11 View Post
    What have you checked, and eliminated as the cause.
    Jun 2006
    Ive seen this issue a few times with that model. The furnaces I ran into with this issue were almost always located near a laundry area and were just a few years old. I ended up finding out lennox makes an alternative flame sensor for this model that they said is more robust. I cant recall the part number but lennox should be able to help you if you have ruled out ground issues.
