Results 1 to 13 of 19
    mystery low voltage problem/ brain fart?
    Hi, all, I'm brand new to the forum but in the trade since 87. Installed a Payne 2 ton 13 SEER r-410A heatpump system in a customers house, 7.5 kw strip heat. $ job took 3 hrs start to finish, and re-used customers honeywell 5000. 2 days later, the od unit is froze up in 30 temps and sounds like a cat trying to get out on defrost. Reversing valve is too small from factory. switched to Goodman od unit, ran fine, a few days later cust has no heat. found popped fuse and no cause for pop. replaced fuse, heat for a few days and pop again, now customer is getting pissed. Ohm'd all stat wires, all the same, no indication of a rub or staple problem, pulled all stat wires from in the walls to show new copper, re-wired, ran fine today, popped again tonight. customer is threatening me with voodoo bad ****, haitian so I believe her! but meanwhile there has to be a logical reason it's popping, I'm just brain farting enough to not find it. Any help appreciated, don't want to be a zombie! Jim
    Salisbury, Maryland
    Hey Jim. So, it sounds like the low volt problem started after you switched the OD unit? I would start simple and make sure the XFMR in the AH is tapped right depending on type of HV feeding it. Energize each circuit independentely (G, W1, O, and Y) and measure your current on the LV side of the XFMR and see if you get a large jump. It would also help if you took out one time fuse and hooked up a resetable one while your troublehsootin' to save some fuses too. If you don't get anywhere with that, I would double check where all the wiring enter's cabinets to ensure its not chaffing. Check the factory wiring too on the outdoor unit. It could be that when the RV is energized for defrost, as 24v is sent to the valve, some wiring may be chaffed against the copper or pinched somewhere against cabinet. Also, you re-used stat? Double check the wiring and programming on the thing.
    3 hours to install a complete system?
    Lancaster PA
    That stood out to me too.
    Jul 2009
    South Carolina
    If I understand this right, you put a new split system in, a few days later you replaced the outdoor unit with a different brand unit because of a problem & now you're having a problem with the fuse blowing in the inside unit. You might want to try putting new shingles on the roof to see if that solves the fuse problem. All kidding aside have you tried running the unit in cooling? Since the short sounds intermittent maybe it happens when the unit goes into defrost & there's a wiring problem or a bad RV solenoid.
    Gary
    http://www.oceanhvac.com
    An engineer designs what he would never work on.
    A technician works on what he would never design.
    I real concerned with the hp brand swapping thing.....................something stinks
    Jun 2006
    Richmond, VA
    Quote Originally Posted by dandyme View Post
    X2
    He can always just throw another outdoor unit at it. Since he already used a payne and gooman...how about a Haier.
    It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!
    Pittsburgh
    Quote Originally Posted by jim hoover View Post
    A new Payne to A new goodman ? In matter of day because of a wiring problem ? Did you change out indoor unit ? 3 hours ? Did you use a vacuum pump ? How did you determine the reversing valve was "too small" ? Im not sure I understand that ? As for the voodoo, maybe prayer, spiritual healing and holy water may help on this issue or even with faults with the equipment.
    Southeastern Pa
    In Philly, they say "it fell off the back of a truck...."
    Calgary, Alberta
    On a 3 hour install, I bet there's lots of tin tape holding things together. Maybe that's the problem.
    Jul 2009
    South Carolina
    If you've really been in the trade for 25 years then you'd understand why by what you posted, its hard to believe you've been in the trade for 25 years.
    Gary
    May 2012
    Upper Michigan
    Voodoo huh? The worst I had a customer do to me was make me eat crappy food they made in front of them lol, sometimes it's hard to say no when people offer you things.
    Oct 2011
    Chicagoland Area
    'm more concerned about the whole brain fart thing. My brain used to do that when I had what doctors diagnosed "$hit for brains" I think I got it all out, although some would wonder...
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
