    SE Michigan
    A fluke question
    I got a little fluke #322 clamp meter. The problem is, the thing will not work unless I warm the batteries up. Is this normal??
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    SE Michigan
    Bump.
    south of Houston
    Did you try a different battery
    Nov 2005
    Kansas
    I would try a different set of batteries if it is still giving problems give fluke a call might need to send it in. Ive had no problems using mine in 25f on roof tops but last time i used it was about a year ago I'm using UEI now.
