Results 1 to 11 of 11
Thread: Hand cramps
    Caledonia WI
    Hand cramps
    Does anyone get hand cramps? I was installing a furnace today in a house that was vacant and below freezing, close to the end of the day both my hands cramped up at the same time it took about 20 minutes to get them to work again. I've had an occasional hand cramp, but never both hands at the same time
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
    May 2002
    Baton Rouge, Louisiana
    Been dealing with one for about 2 years in my left hand, almost like a charlie horse in my hand. Fingers clinch up like a fist and for some reason the knuckle for my pinky sinks down into my hand and I can't get it to straighten out. PITA while I'm driving.
    very soon it is you that will be pwned
    Atlanta area
    Shot in the dark:
    I don't know about hand cramps, but leg cramps are often a symptom of low potassium. Bananas and watermelon are good sources.
    Try eating bananas for a while and see if they make a difference.
    Potassium info:
    http://www.healthaliciousness.com/ar...-potassium.php
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
    Austin, Texas
    Maybe its a sign we are getting older. I notice it more after 50.
    Cramping is also a sign of dehydration, not enough gatorade or water.
    Jan 2011
    I'm no doctor, but I was told that cramping can be caused by a lack of electrolytes. There are many brands of electrolyte replacement powders available at health food stores. Gatorade has electrolytes in it, but it also has sugar. The powders I use have no sugar nor artificial sweeteners.
    In the middle of summer in New Orleans I'm going for the low cal gatorade, bottoms up.
    Desert Southwest
    When I was younger and worked in a potato factory in Northern Maine I would get cramps in the winter when temps were really cold.
    I now usually only get the occassional cramp in my calves which is worse sometimes in the winter when it is less humid and I tend to drink more coffee and less water.
    Catsup also is a good source for potassium.
    If you can't fix it with JB Weld, Duct Tape, and Ty Wire it has to be replaced.
    No good deed goes unpunished.
    If you want to take off friday to go fishing then make sure you train your helper right.
    Nov 2011
    St. Louis
    Yep. Hydration and potassium - I've been taking a potassium pill every day for years.
    I get cramps bad especially in the hot attic. Been taking a magnesium/zinc suppliment and after a month or so it seems to really help. A pharmicist recommended this.
    Western MA.
    Quote Originally Posted by joey791 View Post
    Had a co-worker with similar sounding symptoms,was diagnosed with "Trigger finger" and required surgery to correct it.
    Something to do with the tendons or ligaments in his hand and apparently it was starting to affect the finger next to it.
    I love overtime I just hate working for it.
