Results 1 to 9 of 9
    Feb 2013
    needing a little help
    I own a building which has 11 units most are 5 ton 3 phase 208/230 R22 a few are 7.5 ton
    anyway it is a bowling center we don't try to cool the back end was looking on ebay at this unit
    I wondered if it would help me. it is a Liebert MMC065A-YL2 i read the spec sheet but I cant tell if it will run by itself or
    if it needs another airhandler to go with it.
    stiremup
    Pic is too small to tell.
    Atlanta,GA.
    its a mini mate do you get both pieces it should have a outdoor section that goes with it . it is designed for computer / server rooms i think it is 5 tons
    Feb 2013
    300842934850 ebay there is another one on their store which has no compressor so they tie together this one was on roof supposedly
    Atlanta,GA.
    you will need other half, wouldnt really recommend this unit unless you are trying to cool a server room you will also need the controller(tstat) that is for that unit iyt is a special one that is for that liebert
    Feb 2013
    ok so im probably going to get some abuse but i just found out after 40 yrs of being around it that the dryers on the suction are supposed to be temporary is this new?
    Quote Originally Posted by stiremup View Post
    Been that way for as far back as I can remember.
    Chicago, Illinois
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    ironman597, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
