Results 14 to 26 of 27
    Dec 2009
    15% works well for me
    Dec 2012
    Spokane, Washington
    15% or better...pass the blessings ($) along to the customer.
    A smooth sea has never made a worthy mariner
    English proverb
    Jun 2002
    Dacula, GA
    I prefer Dynaflow by Harris. It costs half as much as Harris Stay Silv 15. Great stuff. Here is Harris's description:
    "Dynaflow melts and flows at temperatures very close to Stay Silv 15, and provides comparable brazed mechanical properties. This makes Dynaflow an excellent cost effective alternative to the 15% silver alloys. This premium, medium range silver alloy has been meticulously formulated to even tighter specifications than our standard copper-to-copper alloys."
    http://www.harrisproductsgroup.com/e.../Dynaflow.aspx
    Sen. Barry Goldwater
    Feb 2013
    Ecellent info:-)
    Feb 2007
    Great Lakes Region
    Ive always used only 15%, but 15% too high now. Went to dynaflow then 5% I find dynaflow doesn't flow as well as 5%. Cant speak for joint strength but never found a leaking brazed joint unless it was obviously misbrazed ( Bugars and/or gaps) Ive heard the brazing material is stronger than the copper and at the looks of todays copper I believe it!
    up in the hizzy
    got free sample sticks of Dynaflow, tried them and dont care for it, it doesn't flow well, it would be good to fill cracks and holes.
    May 2010
    Oxford, UK
    Been using Rothenberger S2 rods for copper to copper. (seems to be industry standard here in the UK)
    5% for braze in sight glasses and driers.
    15% for braze in txv's.
    38% (flux coated) for copper to steel or brass.
    56% for copper to stainless with special flux.
    The S2 rods are about 50p and the 15% ones work out around 14 times that...
    I prefer the 5% and 15% rods but have to cut my cloth according to my means
    May 2002
    Orlando,FL
    Learned using 0% and never had any issue with copper to copper. Only use 15% for things like RV's & TXV's due to its cost.
    Jan 2001
    What about that stuff that comes on a roll.... looks like solder...... Has it also gone up in price ???
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
    Jun 2008
    In the Boondocks near Marion, IN
    Harris 15% for most. Harris Stay Brite for dissimilar metals. Between those 2, there's not much that you can't join together reliably.
    Atlanta GA area
    Doing residential work... most of what I see is CO to CO.
    Dynaflow seems to work well... reasonable flow and good gap filling. Temp control is a little more critical (needs to be a little hotter, yet not hot enough to do damage to other things). CLEAN joints are more important with Dynaflow... as it bonds better to clean (read that shiny) surfaces. As with lots of other things... preparation (of the joint) seems as important as the (actual brazing) process.
    Anything heat sensitive (TXV, RV, etc), I use StayBrite solder. Even a TXV on a 410 system, if the mechanical fit is sung, I have not had any issues.
    GA-HVAC-Tech
    Mar 2010
    Morgan Hill Ca.
    Quote Originally Posted by hurtinhvac View Post
    Higher the silver, easier it flows, less heat needed. Less heat the better.
    Boss is buying 6% as it's cheaper.
    Is it? Think about it like this (not telling your boss what to do) I can braze a joint in half the time using less gas and fewer leaks with 15% than I can with 6%, the chances of having a joint crack upon cool down are increased slightly too. Also, more heat outside the joint = more contamination inside meaning that unless you're using a nitrogen purge, you stand the risk of contamination.
    I think if you really look at it, your boss is not saving a dime. Last time I checked, acetylene and labor is getting expensive too...
    Quote Originally Posted by ga-hvac-tech View Post
    This in an odd way proves my point, the prep work you speak of does not come free.... I am a firm believer in get it fit, get it brazed and move on. We don't use line sets, so the brazing process for us needs to be as bullet and idiot proof as possible.
    X2 on the Stay Brite 8, great stuff IMHO, driers, sight glasses, txv's, reversing valves. I can't see how it would ever have an issue... Even with 410A.
    GT
    If a day goes by and you have learned nothing, I hope you got a lot of sleep.
    Jan 2012
    California
    When I did a bunch of it I always used the 15% for everything. Including dissimilar metals and used Harris Stay-Silv with great results. Only had to carry one product for everything.
