Results 1 to 13 of 18
12-05-2012, 08:28 PM #1
- Dec 2012
- Ottawa Canada
- 6
my evaporator coil is leaking refrigerant. Dectron DSV-020
I have a dectron DSV-020 unit and the sight glass is bubbling when the compressor is on.
I suspect that the evaporator is leaking. (again)
If I get the service company to supply and replace it, what ballpark should I expect the quote to come in at?
the evaporator coil is a flat vertical mounted unit 27"x16"x12" deep.
I'm not looking for anything more than a rough idea. is it $$$ or $$$ or $$$ or what?
I've seen companies on the internet (XYZ) offering an evaporator coil of this size for around $$$.
is that a realistic price for a dectron evaporator coil?
has anyone out there had to do this before? I'm not looking for a commitment, just an idea of what is reasonable.
thanks for your help.
Ole Jensen.
Ottawa Canada.Last edited by beenthere; 12-06-2012 at 07:07 PM. Reason: pricing
12-05-2012, 08:39 PM #2
Sorry, but pricing isn't permitted here.
12-05-2012, 08:48 PM #3
- Dec 2012
- Ottawa Canada
- 6
If I can't ask the question here, do you have any thoughts on how I can get some idea of a ballpark price to do this?
I could ask 4 contractors to come out and give me a quote, but that is unfair to them because 3 of them won't get the job.
thanks,
Ole Jensen.
12-05-2012, 08:55 PM #4
So you would be choosing the cheapest?
12-05-2012, 09:05 PM #5
- Dec 2012
- Ottawa Canada
- 6
perhaps that is what some people do when they ask for multiple quotes.
I never choose the cheapest just because of the price, I choose the one that gives the best presentation at a reasonable price.
that includes explanations of what might have happened, and what can be done to prevent it in the future, if that is possible.
before I start, I would like to know what kind of price I can expect. is that unreasonable?
when I have a deck built, I ask other people what they paid so I have some idea of what to expect.
why would this be any different?
I don't know anyone else that had to replace the evaporator coil, so I don't know who to ask.
12-05-2012, 09:10 PM #6
I certainly understand that and was just trying to stress the importance of getting a quality job done. You don't even really know if its leaking. And by assuming it is bypasses a important step - diagnosing the problem.
I would start by paying someone to look at it. See what they recommend.
Is this a heat pump or what exactly? Never heard of dectron.
12-05-2012, 09:21 PM #7
Professional Member*
- Jul 2006
- Virginia
- 3,705
i would want to know for sure the coil is leaking also using a sight glass to check the refrigerant level is not wise
12-05-2012, 09:47 PM #8
- Dec 2012
- Ottawa Canada
- 6
SBKold:
Dectron is a manufacturer of indoor pool HVAC systems. they are called Dry-o-tron. I came here because there are a number of posts on this site regarding these types of units. Dectron is a well respected manufacturer.
SBKold and catmanacman:
when I saw the sight glass bubbling, I had my HVAC guy come in and check for a leak. he used a sniffer. he is the one who confirmed there was a leak. I did not call in the regional distributor because I find their business ethics questionable. I use a reputable HVAC service company to do the regular maintenance. the HVAC service company has been servicing my equipment for 10 years, but every time I need a part, they are required to purchase it through the regional distributor. I have been in the computer business for over 40 years. In my line of work, I know what controllers cost and I know what sensors cost.
the regional distributor's prices for these items are not reasonable. I know nothing about evaporator coils, so I am looking for some help in determining a reasonable price for the work.
12-05-2012, 10:04 PM #9
Dectrons are specialized equipment so if you need a part for one you are kind if bent over a barrel to buy from them. A sight glass won't necessarily be full of liquid in mild temperatures but if you tech tested and detected a leak then I would concur you probably have a leak. It's impossible to say what something costs bc what something would cost in rural South Carolina could be 1 dollar different than it would cost in New York City or San Francisco.
12-06-2012, 08:10 AM #10
- Dec 2012
- Ottawa Canada
- 6
jtrammel:
thanks for your response. the fact that the difference could be thousands of dollars at least gives me the hint that I am looking 1 dollar to start with. That is what I have been trying to determine.
thanks,
Ole Jensen.Last edited by beenthere; 02-09-2013 at 05:49 AM.
12-06-2012, 08:32 AM #11
Thousands and thousands and thousands of dollars. So what if a guys leak detector goes off it could have been a false reading. At any rate a tiny leak is not a immediate emergency, why all the anxiety?
12-06-2012, 09:09 AM #12
- Dec 2012
- Ottawa Canada
- 6
toocoolforschool:
I was told by my service guy that I need to replace the coil. it is already 10 below here and the humidity is up to 63% and running down the windows. I have been told it will take 4-6 weeks to get a replacement coil.
a work buddy suggested I get them to pump in some R-GLO (?) to identify where the leak is and try to repair it for the winter and deal with the replacement in the summer.
what do you guys think of that idea?
thanks,
Ole Jensen.
12-06-2012, 09:35 AM #13
Sounds like a plan, however welding on the coil could be risky but should be okay those guys are good up there.
