Results 14 to 18 of 18
    Jul 2010
    wisconsin
    Quote Originally Posted by bman03 View Post
    FWIW
    I called my oil company again to follow up on the annual service they (should have) provided and they forwarded me to the manager. He tried to convince me of two things: 1) "No one ever died from carbon monoxide using oil heat" 2) "Oil heat does not produce carbon monoxide like natural gas does".
    Yes, those are quotes.
    I can't confirm #1. #2 is technically true since unburned natural gas is not the same as home heating oil. However, it seems as if he's either ill-informed or he's trying to pull one over on me.
    Find somebody new, and capable
    FWIW
    He doesn't know what he's talking about.
    http://www.extension.iastate.edu/Pag...ns/CO/co1.html
    http://www.carbonmonoxidekills.com/2...onoxide-advice
    http://www.childrenshospital.org/vie...06/carbon.html
    Nov 2011
    CT
    You Should Be VERY Worried
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    jmacho, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Feb 2013
    Boston
    It took about a month of calling (probably not a bad sign that the plumber is busy) but, I finally reached someone at the reference that Jim provided. Unfortunately, I am out of their service area. That guy referred me to a company closer to my home. When I called them they said they don't normally work on oil systems but, would be willing to come out and look. The guy at the 2nd company said they had instruments to measure O2, CO2, and CO.
    Should it be this hard to find someone who works with oil and has current training in the Boston area? Can someone provide a reference closer to the 02453 area?
Tags for this Thread
