Results 14 to 26 of 26
Thread: Shaft alignment methods
02-10-2013, 10:01 PM #14Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
02-13-2013, 02:08 PM #15
The outfit I used to work for needed documentation on a couple of jobs so we bought a laser alignment setup. You could learn to use it in about half an hour. I brought a class in on a Saturday and trained them how to use dials (we had a pump on a base). Once they got a handle on that we broke out the laser. All picked it right up. After that our young guys who went to the class could run rings around the guys who didn't want to learn the laser. It also provided printable documentation of the alignment.
Nos operor non pensio volutabrum
02-13-2013, 05:25 PM #16
- Nov 2004
- Western NY
- 984
all the laser systems are based on reverse dial alignment, I've never use the laser but I see guys using it and its pretty simple, straight forward system, the computer tells you what size shim and where to put it, the only reason I still use indicators is money, the laser cost 10 times or more the price of the dial indicator setup, I also think that by dummy down our trade we are shooting ourselves on the foot.
02-13-2013, 08:42 PM #17
You really can't go wrong with the thumb up, left eye closed method.
02-14-2013, 07:39 PM #18
Professional Member*
- Oct 2004
- toledo, ohio
- 52
I use a good ol stick rule on belt drive units.. I teach the newbies the 4 point rule on straight edges and use dial for the big boys... Everyone is correct when they say it is a dying art. I only do about twice a decade, which makes for a poor showing on my part.
02-15-2013, 06:32 PM #19
Just for grins, take a shaft and fix your indicator to it. Zero the indicator and then turn the shaft over and see what it reads.
02-15-2013, 07:22 PM #20
Pictures and/or videos would be nice.
- Alexis de Toqueville, 1835
02-15-2013, 09:05 PM #21Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
02-16-2013, 05:45 PM #22
02-16-2013, 06:03 PM #23
02-16-2013, 07:46 PM #24
- Nov 2004
- Western NY
- 984
02-16-2013, 11:03 PM #25
- Dec 2008
- Dixiana, AL
- 2,499
Why would it be an issue? Sag is nothing but a natural force that's going to be repeatable if the setup is the same. Simply set your indicator up on a piece of pipe or shaft over the same span as your work will be done, zero, roll 180°, read the sag, compensate at 12 o'clock before starting your vertical parallel reading and read 6 o'clock directly. Longer the span, worse the sag. If you test the runouts on all parts and they're within tolerance, then the only part of the process that sag is an issue for is the vertical parallel. Sag is the reason that I use face and rim instead of reverse indicator. Easier for me to deal with in that manner.
02-19-2013, 11:41 PM #26
- May 2008
- Collinsville, Tx (Texoma)
- 30
Dial indicators work, but when a customer requires documentation laser alignment is the way to go. The company I work for has a laser alignment tool for shaft alignment. Most of our trucks have Pulley Partners for Pulley and belt alignment. The laser shaft alignment tools are not cheap, I think around 5k for a cheap one and like 15k for the high end if not more. With a laser alignment you have a calibrated instrument to tell you you have it right. When we higher a vibe and alignment company they use a laser alignment, but also have dial indicators to check run out.
(Hey - you opened the door)
