Results 14 to 19 of 19
Thread: Aaon units
    Quote Originally Posted by hvacman2213 View Post
    i have 4 Aaon rooftops on top of a hotel in Naples. And two of witch have no charge i spent all day Friday looking for leaks. units are 2 year old i put 200psi of nitro and 1lb of 410 as a trace gas after spending 2 hrs looking for the leaks with my crap tech mate leak detector and my psi dropping 5psi. I went out and got a fieldpiece leak detector witch cost me $305 come back and find leaks in my reheat coil valve on both units. After calling around a rebuild kit is $407 my valve $420 i need 2 and 65lb of 410. so this week i strongly dislike Aaon.
    Those step valves aren't real easy to braze in the way they're mounted at the side of the unit.
    Southeastern Pa
    Funny.
    I heard Aaon was designed by two former Lennox guys.
    SouthEastern Virginia
    Sometimes the assembly line forgets to wrap those reheat valves with wet rags and that's why they leak-not because the valves are crap.
    It might get loud!
    Jun 2012
    We had an L series class in the shop and they brought a trailer in with an RTU to let us look at it and see it run. I was new and I asked "did you guys copy an aaon?" they did not think it was funny.
    We see a wide range of Aaon unit types and ages. Their old stuff is good and the new stuff is built like the old stuff. A lot of times when I work on them i find my self asking "why doesn't anyone else do it like this?" those units were old too. Things seem easier to get to, coils seem more robust and most of the time are slanted, hinged doors and latches with hardware to hold it open, slide out blower assembly's, gear drive economisers, etc etc. I am mostly talking about general RTU from small to 50t. Not every Aaon is great like the liebert wannabes we see. I have changed a lot of parts out on RTUs and for the most part they seem a little smoother than most. In our shop the most grumbling I hear is startup issues and bell and whistle overload.
    Mar 2009
    Mid-Mo
    Some of the other manufacturers could take a lesson on their wiring diagrams. One of the easiest diagrams to read IMO.
    Jun 2012
    I second that and it is protected from the elements
