Results 1 to 13 of 19
Thread: Aaon units
    Feb 2011
    Aaon units
    Hey just wondering what anybody thinks about aaon rooftop units, and what's your experience you have had with them. I just looked at one a few days ago and I found they can be a little tricky if you don't know anything about their wattmaster control.
    Mar 2009
    Mid-Mo
    Ya they are ok. You have to learn their quirks and nuances. Once you figure that out then it's just another rtu. Make sure you use OEM condenser fan motors......
    Jul 2012
    Western KY
    The controls can be aggravating till you get used to them, like any other. I like the serviceability of them. Put to gather with taking apart in mind.
    SouthEastern Virginia
    I work on em all the time-have my own handheld programming tool which is a necessity. The makeupair units can be pretty complex when you make them a watersource heatpump with heatwheel, modulating hot gas reheat, and add an airflow measuring station. We can make it even more complex by bacnetting to a Johnson Controls front-end. Any questions?
    It might get loud!
    Southeastern Pa
    I'm only 5'10 and I have to bend down to look into the control section.
    I found that the Watt Master System is kind of a p.i.t.a.
    I DID find it the Orion technical support was pretty good. With only one site using Aaon units we're not going to get that handheld device.
    Nov 2012
    I am really pleased with Orion tech support, the Aaon units them selves, not so much.
    Hey Timebuilder you should get one anyway and go after some more Aaon jobs. They will keep you busy I promise.
    It might get loud!
    Southeastern Pa
    Quote Originally Posted by duke of earl View Post
    Well, how many sites we get with Aaon units is not my call. Plus, I would have to buy the tool myself.
    Sep 2012
    cape coral FL
    i have 4 Aaon rooftops on top of a hotel in Naples. And two of witch have no charge i spent all day Friday looking for leaks. units are 2 year old i put 200psi of nitro and 1lb of 410 as a trace gas after spending 2 hrs looking for the leaks with my crap tech mate leak detector and my psi dropping 5psi. I went out and got a fieldpiece leak detector witch cost me $305 come back and find leaks in my reheat coil valve on both units. After calling around a rebuild kit is $407 my valve $420 i need 2 and 65lb of 410. so this week i strongly dislike Aaon.
    This.
    Feb 2013
    Michigan
    I think they are the best built and most thought out RTU on the market. I find the very easy to work on and service.
    Quote Originally Posted by Akkarek View Post
    That's how I feel about Lennox L series units
    Sent from my SGH-T999 using Tapatalk 2
    Feb 2013
    Michigan
    I would agree they are right up there in design and quality. I don't know if its true but I remember being told that several of the Aaon engineering were recruited by Lennox to create the L series,
