Results 14 to 26 of 28
    Apr 2012
    Pasadena,Maryland
    I have a tubing cutter with a deep blade I bought online, problem with it is seems to distort the roundness of the pipe, it does make clean straight cuts. I saw this tool online that is used to press the pipe into the fitting but I don't know how that would work in the ceiling , probably one of those things you need to use on a bench.
    TIP-O-TX
    Is this the so called SAW SAW that Tech Rob was inquiring about.
    Quote Originally Posted by hvacvegas View Post
    Attachment 354801
    and for the shavings:
    Attachment 354811
    Jun 2002
    south jersey
    I had a Home Depot one that broke on one side and then cut straight. But it finally crapped out. I tried to break my other one in the same place without the same results. I only use them for up to 1 1/4. Everthing else is cut with a saw saw.
    May 2013
    De Pere, Wisconsin, United States
    I have the Lenox R2's and they cut great. It's a spendy tool but it works good.
    http://www.lenoxtools.com/Pages/Prod...+TUBING+CUTTER
    Has anyone else noticed issues of using a pipe cutting on cold PVC? Seems to destroy the blade.
    Sep 2013
    I use the Rigid for up to 1" and it cuts fast and square. Anything bigger and a sawzall with metal blade is the way I go
    Jul 2011
    N.E. Ohio
    I've used my DeWalt miter saw on some bigger plumbing jobs. Works great, but I don't think I want to lug it to the basement for a half dozen cuts for a vent and Combustion air piping. The tubing cutter works good, it is a different wheel and is slow. Sawzall or PVC saw and a couple twist of the reamer, deburrer works for me.
    Jan 2001
    Sawzall or a porta band.
    The bible is my constitution and the constitution is my bible.
    WE THE PEOPLE refers to THEM and not YOU.
    Chewbacca Mom 2016
    Apr 2012
    Central NJ
    I have been using a Lowes Kobalt Brand, and so far they have cut great for the past year. Also on bigger pipe I use a sawzall, but I make sure and use a high tpi blade like a 24.
    Sean
    Oct 2013
    West Hartford, Connecticut, United States
    I have a klien. Works good for me. 1.5" and above I just use a sawzall a cutter would be cool thou. Maybe I'll look into the miluakee 18v
    Jun 2012
    CT
    A lennox hack saw and a sharpie can get you pretty far
    Sent from my SM-T217S using Tapatalk
    Dec 2013
    If you've got power then cheat - get a chop saw cheap somewhere! Always cuts straight and fast.
    When I don't have power I wrap paper around the pipe so its edges are flush then use a felt/pen to mark the circle. From there cut on the line (but not through the pipe) only on the side facing you and rotate the pipe to cut some more. usually takes me three or four complete rotations of the pipe before I cut all the way through. You get a very straight cut this way.
    Learned that from a plumber when we were installing 8" Sched 80 for a public pool circulation system. If you do it a lot then instead of paper you can get a special roll of impregnated/marked material from a plumbing supplier thats specifically for marking cuts around pipe.
    Jul 2009
    Kansas
    Called a Wrap-Around ^^^
