Results 14 to 26 of 29
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Lancaster PA
    chevydriver29, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    Anderson SC
    Post the video, I want to see it...
    Keokuk, IA
    "Visit" in the contract probably didnt explicitly they actually did anything other than look at it. .
    Home warranty comaponies are usually worthless. Better to just have it fixed right out of pocket... since you will likely be doing that in the future anyway.
    Sent from my SGPT12 using Tapatalk 2
    Lancaster PA
    Where is it that a home warranty company is involved?
    you should have video taped it and the company would be receiving a heathy fine. the main issue is the should have got authorization for the refrigerant before putting it in .
    Jun 2011
    Houston area
    The original title to this thread was "Dirty coils use less freon than clean coils? Seriously?
    One thing that everybody here needs to understand is not just no but hell no. A heatpump, regardless of what type of metering device is used, is a critically charged system. The condition of the coils, blower speed, return air situation, plenum size, ductwork or the price of tea in China is absolutely mute. The ONLY way to charge a heatpump correctly is to weigh the charge in and use the manufacturers specs on lineset length to adjust the charge. It is the ONLY way.
    Your home warranty contractor is full of that steaming BS you mentioned.
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    we charge them up all the time and we do not recover all the refrigerant and weight it back in ,also a dirty indoor coil will run up the discharge pressure and can run up the suction pressure ,a clogged outdoor coil can lower the suction pressure and also lowers the discharge pressure . all you need to do is get the charge close then come back in the spring and fine tune it refrigerant is to expensive to be sucking it all out the weighing in new
    Jun 2006
    Richmond, VA
    Quote Originally Posted by mspeter View Post
    Believe me I understand your caution. Been there done that. The difference here however is we didn't call them out for service. We called them out to have them perform the annual system checkup and coil cleaning we had paid for the prior year so we were not having trouble beforehand. IF it was low on freon beforehand, we were unaware. Point is we didn't call them out to fix a leak. And when it's all done we are left with one unit totally inoperable and told it was bone dry on freon, but the second tech disputed that and said it was not bone dry but low six pounds. And after what the manager told me I had to come here to ask the question - was what the manager told me reasonable under the cirucumstances or was it mumble jumble to baffle me with BS because I wouldn't know any better and to get me to pay them more money to fix what I think was their screw up. BOttom line now is oh yes we have one unit that is definitely low on freon because I watched him venting it. Obviously I need to call another company now to get it taken care of but as far as that goes we have a home warranty which is precisely why I told them I didn't what them to do any repairs when I spoke with the first manager. They wanted to check it to see if it had a restriction or not which is what the first guy was saying why it no longer worked. I was planning to go back to the company and speak higher up the ladder but honestly I don't trust them any more. So now I guess I hope the warranty company will still cover it despite those clowns monkeying with it, and if not go to the BBB and the consumer help lines at the local TV stations. Oh joy. By the way, when I saw the guy venting it I took out my cell phone and appeared to be reading email but really i was video taping it. You should hear the hissing sound of that stuff being released. I wonder if the TV consumer guys might be interested in investigating that?
    So....they came out for a system check a year later....find it low on freon....and its their fault? Leaks can develop anytime and it could have been fine during the last check.
    Has your electric bill gone up over the last few months more than normal? With heatpumps with electric backup, if the heatpump quits working right the electric heat runs more (and most people do not even know it because the electric heat keeps the house warm) however the electric bill goes thru the roof.
    It's not the Brand with the fewest repairs-It's all in the install!!! Attention to detail and using the best materials!
    When all is said and done I beleive this man received poor service. I beleive the tech. was on a commission base salary and was trying to up his pay check.
    Certified parts changer.
    Southeastern Pa
    There's a missing piece of information.
    Was the unit that was allegedly low on freon (regardless of whether was bone dry or down 6 pounds which is pretty much the same thing on a residential unit) actually working correctly prior to the service visit?
    If it hadn't run since the previous season you wouldn't know if you developed a leak or not until the technician looked at it.
    Without being able to hear both sides of this story, I have to tell you the purpose of a maintenance visit is to see if things are working right. You see, neither you or I can say the system was working correctly up until that technician arrived.
    Dirty coils can change pressures. If you purchased a maintenance plan based on cost alone then you may have a technician who relies only on pressures. In that case it may be time to get a referral for a good company and perhaps have to pay more for a better maintenance plan.
    If coil cleaning was a part of your maintenance plan, then dirty coils should have been cleaned. In fact it is possible that you may have been paying only for inspections.
    Other dynamics aside, if you can't find the installing contractor and get them to repair whatever leaks you have, then you're going to have to pay somebody else to fix them and recharge your system, and the manufacturer won't cover that.
    Jun 2011
    Houston area
    ...........dirty indoor coil will run up the discharge pressure and can run up the suction pressure , a clogged outdoor coil can lower the suction pressure and also lowers the discharge pressure . all you need to do is get the charge close then come back in the spring and fine tune it refrigerant is to expensive to be sucking it all out the weighing in new
    Are you real sure about that?
    ,,,,,,,we charge them up all the time and we do not recover all the refrigerant and weight it back in.........
    Yeah, lots of technicians do this, doesn't mean it's correct. You simply cannot know exactly what's in the system unless you weigh it ESPECIALLY if everyone and their dog and you has jacked with the charge and ESPECIALLY on heatpumps.
    And to reiterate, dirty coils DO NOT use less "Freon" than clean coils.
    I'm still betting on that steaming pile of BS.
    LMAOSHMSFOAIDMT
    Quote Originally Posted by Cooked View Post
    yes im sure if the evap coil is clogged it is not absorbing heat properly and in heat mode the outdoor coil is the evap coil
    dirty coil can skew you temps and pressures
    im agree with you on this
