Results 1 to 13 of 18
    Jan 2013
    Coleman Mod fornace
    Can a modulating furnace be zoned? I am referring to a new Coleman mod.
    I would suspect that due to the varying fire rates and, like wise the varying airflow, that zoning would be a problem
    Am I right in my assumption?
    Yes. There is a jumper on the board that removes the "run 2" feature.
    If you're working on these units, I would suggest getting a copy of the technical training manual. This is not your average furnace.
    Chances are you'll need it at some point.
    Jan 2013
    Quote Originally Posted by 2old2rock View Post
    Yes I know. Our supplier (johnstone) promised us a training seminar when we signed on for the mod but the class was never scheduled or has plans to be.
    Can you provide a source for the service manual you mentioned? Coleman tech service never returns my calls and I have waited an hour on hold only to be told to leave a voice mail.
    Athens, Ohio
    Quote Originally Posted by hvac5646 View Post
    With support like that, where do I sign up?
    Mar 2012
    West Chester, PA
    a digital copy of the technical manual can be found at UPGnet.com (if your distributor has gotten you access) under technical services, training, digital publications. These are not printable versions. Paper copies may also be ordered through UPGnet. The zone jumper is the only change that needs to be made although there are some set up steps that need to be followed also. As stated above, this isn't your daddy's furnace. Get the manual
    Tell Johnstone if they want you to sell that furnace, they need to get you the Technical Training Manual, PRONTO.
    Then read it front to back, and back to front.
    This furnace will turn you upside down if you don't understand why it's doing what it's doing.
    Jan 2013
    We informed them of that. Still got no where. Branch mgr blames his boss for the problem. Coleman Factory won't return our calls. Johnstone says they know nothing about getting dealer access to UPG website.
    Anybody able to lend a hand or email me a copy?
    Jan 2013
    I called the branch this morning and had a very frank discussion with mt "go-to guy".
    He is going to talk to the outside sales rep and see what he can come up with.
    You'd figure he would have been first in line to be contacted.
    I'll post back the outcome.
    Jan 2013
    Mar 2012
    West Chester, PA
    The way that they are stored on UPGnet prevents them from being copied or saved for further distribution. You have to have access or buy a hard copy. The only other way would be to print screen every page of the 200+ some pages... maybe someone can help you out with that... good luck
    As long as your using N.O dampers, no problems with zoning weather or not you disable run 2.
    Jan 2013
    Thanks for the replies.
    I got no where with Johnstone. Now I'll have to find some other avenue to get the tech manual.
    Johnstone just lost some business.
    Mar 2012
    West Chester, PA
    It is probably because they don't have a dealer program. They basically just buy and sell the equipment. That is what the Johnstones around here do. They aren't very good in terms of support. They are a general parts house, not a distributor. As a consequence, they just aren't set up to support you the way that they should. Johnstones in my area have been responsible for the downfall of some name brands because of the fact that they sell equipment to ANYONE and offer no support or training. As a result, all the hacks buy their equipment from them, that equipment goes in incorrectly, the units do not run the way they should and the brand gets a bad name. The issue of course isn't the equipment but the fact that johnstone is willing to sell to anyone with money and offers no training or support. You should get your equipment from a real distributor instead of a parts house. Of course JS is a franchise and each one is run differently... this does not apply across the board. I know some Johnstones that participate in dealer programs and are very good but that seems to be more of an exception to the rule than the standard. Good luck
