Results 1 to 8 of 8
    Jul 2003
    lvl ky
    Question The Condenser fan SHOULD be on right?
    I believe I know the answer, but I'd like to check myself, for my dads sake. He has an Amana refrierator model TR21S4l serial 9606119548. When the compresser runs, so should the condenser fan, right?He's being told by Amana and some other guy that "not always", sounds wrong to me.
    Apr 2012
    winnipeg
    its possible..... if there is a control to cycle it......not a appliance tec.... can't say fo sure...
    hearth planet
    If it's wired in parallel with the compressor it will, if wired to a board or diferent circuit it could cycle.
    Oct 2011
    Chicagoland Area
    I would doubt the condenser fan cycles on a resi refer, but what the hell do I know?
    Jul 2003
    lvl ky
    thanks guys, i'll have to get a schematic i guess to be sure
    PNW
    The vast majority of Resi refrigerators are wired with the condenser fan to run in parallel with the compressor. Only very modern, high end resi units have any advanced controls to cycle the condenser fan. Not directly familiar with your unit, but assume the fan is supposed to be running.
    Does it kick on at all?
    Tampa Bay, FL.
    I've never heard of a condenser motor not cycling with the compressor. Is the compressor kicking out on overload? Is it a reversing fan motor? If so, perhaps the timer is bad or a bad wire so it's not spinning on reverse cycle.
    Jun 2009
    DFW, TX
    This made my day.
