Results 1 to 15 of 15
Thread: Fan auto or on
    Fan auto or on
    I have a question about the fan on or in auto mode.
    The bearing in the blower motor went out and the service tech that replaced it suggested I leave my fan in the on position instead of auto, I have always thought the auto was more efficient than the constant on and thus have always set in the auto position. Which is reccomended or more efficient for the life of the system?
    Jun 2006
    Southeastern Connecticut
    Auto position is cheaper to operate. On position will be better because of air is always being filtered and circulating but the cost to run blower will be much greater unless you have a variable speed unit which you dont. I don't think the life of the motor is affected that much by the cycling.
    burlington county n.j.
    depending on furnace model and layout of registers fan on could make house feel cold and dafty in winter.
    Apr 2006
    Indy IN
    Quote Originally Posted by t527ed View Post
    If his system is balanced then leaving the fan on will bring more equal circulation to the entire house. If the returns are located high then it could save on the gas bill b/c the fan will circulate the air more equally throughout the house.
    Don't settle for mediocrity, set higher standards for yourself than the rest.
    Jul 2005
    and then again , having the fan "on" could also make the house feel very comfy.,and perhaps save a few burner cycles over a short period of time.
    try it ,you may like it.
    Houston,Texas
    Depends on the season I guess, I know you sure don't want to leave in the "on" position during the summer your humidity control will not be as good.
    “Experience is a hard teacher because she gives the test first, the lesson afterwards" ~ Vernon Law
    "It's what you learn after you know it all that counts." ~ John Wooden
    "When the teachers become unteachable we're all in trouble" ~ Mr. Bill
    "Remember "Pro" is only a name, it's not always a mindset determined to do everything correctly" ~ Mr. Bill
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by iuhoosier View Post
    the bearing will wear out quicker if its running the whole time i would think!
    (would not matter much on v.s motor)
    Florida
    "on" or "auto" is just personal preference, with "auto" being less costly to run. The bearing saving position is "off".
    Naples, Fla.
    Notation on Fan Auto / On
    IAQ - you will have improved IAQ with the fan ON
    Seasonality - You will have a more comfortable home for most heating applications w/ fan ON. Note also on newer systems a fan ON call results in a 35% - 50% low speed default when heat / cool is satisfied.
    With exception to intermittent ventilation needs, IE:a party in the home - the fan must be in the AUTO position for cooling. The only exception to this rule will be IF you've invested in whole house dehumidification.
    On bearing life --- I seriously doubt any measurable difference exist between life expectancy of ON vs Auto.
    Apr 2002
    In heating climates the constant fan can even out the temperatures, however can feel drafty if there is a fresh air intake open.
    In cooling, constant fan will drive up RH. If you are not that humid of a climate it may not be a big deal.
    http://www.ductstrap.com/
    Quote Originally Posted by coolguysfl View Post
    well put
    Work smarter... not harder.
    Quote Originally Posted by Carnak View Post
    This has been my personal experience. I find there is much less temp differential between floors when I leave it on all the time.
    SC
    If you have leaky ductwork, the ON position will drop the efficiency of your system. However, the proper fix would be to seal your ductwork.
    In a properly sealed system, there is very little efficiency or bearing wear difference with the two positions. Try it both ways, and run it the way you like it.
  14. #14
    Raleigh,NC.
    the biggest complaint with winter "fan on" ,is the cooling affect with 68-74 degree air swirling around a 98.6 degree body.having said that, fan on tends to equilize room to room temps, but insummer increases the humidity after t-stat has satisfied by evaporating the water left in the drain pan under the cooling coil. some newer coils claim a positive flow by downhill construction.I turn my fan on in late spring and off in early fall except those extremely humid days, because my coil's pan holds water.as previosly stated, personal preferrence and some electricity.
    remember, with electronics; when its brown,its cooking and when its black, its done!!!
  15. #15
    Dec 2006
    Middle Tennessee
    lets break that down,you have a serious doubt that a motor that runs
    all the time will have the same bearing wear as a motor that does not run
    all the time,i seriously doubt that that makes any sense whatsoever!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
