Page 1 of 4 1234 LastLast
Results 1 to 13 of 48
    U.S.A.
    Best Recovery Machines
    We need to purchase several new recovery machines for general every day use for commericial HVAC service.
    Can anyone make a good recommendation for a machine for a service van?
    Looking for a portable machine which is dependable and has a high capacity recovery rate. Tried several different types of machines the wholesalers are pushing, but they turn out to be junk w/ low recovery capacities and generate too many compliants from the service mechanics.
    We might be looking for something that isn't made, any ideas?
    Oct 2006
    Emerald Coast, FL 30.1N 85.8W
    Appion G5 seems to be the rage on this site, but you might need something bigger for commercial.
    I'm going to buy one.
    Sep 2006
    Ma.
    Are company uses the Thermaflo Recovery Machine . It is a pretty good machine and has a two year warranty. It can take a lot of abuse .
    /http://www.koolit.net/new_page_3.htm
    Only 23 lbs.
    1 Horsepower Wizard Compressor with High Start-Up Torque
    Recovers High Pressure
    Patented Sub-Cool & Self Evacuation Feature
    Simple to use and lightweight
    Recovers all high-pressure refrigerants and blends, including R410A
    Subcool for pulling deep vacuums in high ambient temperatures
    Recovers both liquid and vapor without changing hoses
    Oil-less 1 HP compressor
    Switchable 80% tank overfill protection
    Strong, ergonomically designed case
    Simple two-hose hookup
    Two-year warranty
    Availoable also through johnstone supply model #H85-326
    http://www.johnstonesupply.com/scrip...yes&category=4
    North Florida/South Georgia
    I like Promax
    Here are a few things to consider about recovery equip in general.
    1) You need a dedicated set of hoses that have no schrader depressers in them.
    Never recover through your manifold.
    2) You should have a TEE on the recovery unit so you can hook two hoses to it, you can also have a TEE on the outlet if you want to fill more than one drum at a time.
    3) Always have two valve core removers on hand that allow you to remove the schrader without recovering the charge, therefore you can use your hoses without depressers, that way everything is full flow.
    4) Have a complete understanding of what push/pull is & how it works.
    So many people do not understand this & they try to use push/pull & conclude that it does not work.
    It does work, you just can't push/pull through metering devices, compressors, check valves or a LLSV.
    Most of the time, the vapor recovery method will work best on unitary products as long as you have a recovery machine that can handle some liquid when you adjust the restrictor valve down around 50 - 60 psi.
    5) Last but not least, never under estimate ice or water for the recovery tank.
    Ice is better, if you can't get ice, atleast use water.
    Its worth the hassle everytime.
    All my leon freaked out!
  5. Likes JonesHVAC liked this post
  6. #5
    Baltimore area
    By far the fastest I have used !!
    I have had it for about 1 year now . I was the first tech in our shop to buy one and now the boss has bought them for everyone . I have probobally pumped 5,000lbs of liquid refrigerant through it , charging and recovering and I have never had a problem with it . I have clocked it @ just over 7 lbs per minute while charging or recovering liquid .
    Before this one I had the CPS liquid pump and it sucked !! Biggest POS recovery unit I have ever used .
    Stick with the Appion , you will not be let down .
  7. Likes JonesHVAC liked this post
  8. #6
    Oct 2006
    I think thermaflo has a modular recycling unit
    Do you know anyone that has used the modular recycling unit that can be purchased for it? I'm interested since that would be an attractive option.
    I think that's the company that offers one.
    Quote Originally Posted by kpaul View Post
    Only 23 lbs.
    • Recovers all high-pressure refrigerants and blends, including R410A
    • Subcool for pulling deep vacuums in high ambient temperatures
    • Recovers both liquid and vapor without changing hoses
    • Oil-less 1 HP compressor
    • Switchable 80% tank overfill protection
    • Strong, ergonomically designed case
    • Simple two-hose hookup
    • Two-year warranty
  9. #7
    Jul 2003
    Orange County N.Y.
    Like others that have posted I use the Appion G5 Twin. I have also run #1000's of pounds of refrigerant through it and it kicks a$$ everytime. One time it took about 45 seconds to pull 1 pound or R-11 out of an old Carrier 19C machine into a sample bottle. The machine was setting at 10" of vacuum. Another time I let a co-worker use it to pull #150 lbs. of R-134a out of a Carrier 30hxa used to make ice at an ice rink, his RG5410a machine was only making 1 lb every 8-10 minutes... Refrigerant temps were right around 0-5 degrees.
    The direct suction is what makes it the best for our use. The oil doesn't wiped from the crank bearings with the introduction of liquid.
    ...Ron
    Roof Rat
  10. Likes JonesHVAC liked this post
  11. #8
    Jan 2006
    Hangin out with you losers
    APPION gets my vote
    http://www.appioninc.com/hvac/g5features.html
    easy to climb with
    Before that I had a STINGER used 1 summer got stolen
    before that a FLOUROMIZER lasted forever just to heavy.
    Also print off chiller mekanik post any combination of those techniques will cut recovery time down drasticly.
    I remember my first day,It was fun!
  12. #9
    Baltimore area
    I forgot to mention that the Appion only weighs 21#'s . The thing literally is lighter than my everyday toolbag .
  13. Likes JonesHVAC liked this post
  14. #10
    crossville
    Talking i have six of these
    Quote Originally Posted by refrtech View Post
    when you pull them on roof its the lighest on the market, and best one out there, i just finished two years on road warrenty work, we pumped out 1000 machines,i can supply pics, averaged 50 lbs per machine, only had two units go dwn on cracked copper lines, easy to fixthem up and keeped pumping. they r two cylinders, pump out alot of freon quick and draws down to low vacuum. great unit, i had used the promax(POS) THE CPS HEAVY AS BRICK AL BOXES THAT WEAR OUT, breaks rods and doesnt pump down
    If you cant cool it
    HEAT THE Hello out of it
  15. #11
    Mar 2011
    Abilene Tx
    Quote Originally Posted by chiller mekanik View Post
    Just curious as to why you say never recover using your manifold gauges. Not trying to argue, just want to know other technicians ways....I learn things that way. I never had any problem using my manifolds to recover. I have also heard people talk about taking cores out, using bigger hoses to recover...........less restriction and all but maybe I'm just a simple guy but I have recovered just fine. I, like the craze, use the Appion G5 Twin. I recently took 68 pounds out of a McQuay chiller in about 30 minutes or less I figure...didn't keep track but it was quick. I also like the thing because I can just turn it on and leave, I don't have to sit and adjust the throttle so the liquid wont hammer the dang things!
  16. #12
    Quote Originally Posted by Cowpoke View Post
    Try to have MINIMUM number of restriction as possible when you recover/vacuum
    It is like "sucking soda with small straw or large straw". Which one will require less work of your lungs?
  17. #13
    S.E. Pa
    Just Opinion,
    This is the Ask Our Pro's or AOP forum. In order to post responses here, you must have verified qualifications and have been approved by the AOP Committee. Please see my signature line for links to register and review the AOP Forum Rules. Thank you. Your post will now be deleted. Further infractions may result in loss of posting privileges.
    Cowpoke,
    Please do not dig up old threads prior to November 2011 to ask questions or respond about them. The respondents may not have been vetted so we have no control over their posts. If you find information in an old thread, you as an equipment owner should start a new thread. You can copy the URL of the old thread and paste it into your initial post as a reference. Vetted Pros with their * can then respond to your query here.
