Results 1 to 11 of 11
    Apr 2010
    ft.worth tx.
    what test leads do you use
    to check voltage in molex plugs on ecm motors or carrier defrost boards
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by blaster50 View Post
    The defrost board molex plug has a bare metal spot on the side to be able to check. I've never had a problem checking it on the ECM and just use the fieldpiece test leads.
    May 2009
    Savannah, Ga/H.H. Island, S.C.
    I just purchased a set of the Fluke TL910 leads. They're very small and are designed for electronics. They have very fine tips. Perfect for molex plugs, sensors, transducers and such.
    Jun 2011
    Muncie, Indiana
    Fieldpeice makes a great lead set, part number ADK7, it has regular lead tips, needle lead tips and alligator lead tip. Best investment I have made in a while
    The only true knowledge is the pursuit of knowledge
    Apr 2010
    ft.worth tx.
    thanks for the info.I'll check them out & get me a set
    Feb 2013
    Huntsville, AL
    Yes, Fieldpiece is what I run and I would buy again if I had to.Bought mine back in 2006 and it still works great!!
    I had a PITA problem on a Trane rooftop and "customized" a set of probes.
    I couldn't fit the standard tips into the little slots cut into the plugs so, I filed the tips sharper and bent hooks onto the ends.
    Worked great as a field expedient fix.
    Oct 2007
    Mount Gilead, Ohio
    Go to radio shack, they have a nifty little kit for like 20 bucks for electronic leads. Comes with several different leads. I'm looking for a moles plug pin removal tool. Seen them on the Internet just would rather buy one in person
    Jan 2011
    Highland Park, CA
    Using a short piece of t-stat wire and your alligator clips works in a pinch for most molex plugs, but the ADK7 is the way to go.
    I cut a paper clip in half and use my alligator clips on one end and the other end into whatever.
    the ADK7 is something I may be interested in at some point.
    Quote Originally Posted by in-trane-ing View Post
    I never found one locally, but not in a huge city.
    I bought one off the internet that was 2 sided and it has worked for me so far.
