Results 1 to 13 of 19
Thread: Rebranded units UGH
02-04-2013, 08:59 AM #1
- Oct 2012
- 26
Rebranded units UGH
WHY on earth does the HVAC industry re-brand their units. It makes it impossible to see what you're getting. So here's my question...if I ask a reputable vendor who makes their "rebranded" unit, should they be open and tell me or is it information they will not share?
02-04-2013, 09:19 AM #2
Professional Member*
- Dec 2002
- SouthEast NC ICW & Piedmont Foothills
- 7,219
they should inform you what company actually produces the equipment being offered; since it doesn't take much effort to find out.
most all manufacturers produce more than one line of product.
02-04-2013, 09:36 AM #3
- Oct 2012
- 26
Thanks so much!
02-04-2013, 09:37 AM #4
Might be a good time for home owners to stop thinking about brands and think components. Lets start out with the Copeland Scroll compressor, #1 in my opinion, if your looking for high efficiency then they should have a "double row" condenser coil, then low pressure and high pressure switches are also a plus, louvered sides is good for protection from the elements. I am a Ruud dealer and I like the easy access service area. As for as furnaces, you want a limited lifetime heat exchanger warranty, and 10 year parts warranty, the ECM 2+ motor is a good also and I like the serial communicating capable models. This is a good start if your looking for quality, most re-badged or second lines will not offer any of the above.
02-04-2013, 09:40 AM #5
- Oct 2012
- 26
All good stuff Mr. Bill. RIght up my alley because I like to research everything (even things I know nothing about like HVAC). But I'll tell you that my posting in this forum with even the most basic question is probably more than 95% of people do when looking into this investment.
02-04-2013, 01:05 PM #6
- May 2008
- Missouri
- 2,623
The reason larger HVAC companies "re-brand" is to simply build loyalty with their company and not some big box branded company. They simply buy someone else's unit, and re-sticker it. Their company stands behind the warranty needs, so you continue to do business with them and not another dealer for the big box branded equipment. These companies usually find a brand that is dependable, yet reasonably priced that won't have a lot of warranty issues. Everyone wants to "talk" about the latest and greatest "breakthroughs" in the HVAC business, but as a HVAC dealer who has been around for a long time....sometimes equipment comes to market with problems that have not been solved and the end user (you) has to take care of these problems. Most major manufacterers rush to market due to their competition and sadly the end user gets caught with defects and "why didn't they think of that" type problems. Also remember that the out of warranty repairs for super complex equipment will be very expensive!! This is the reason most larger HVAC companies do not "re-brand" the higher end multi-stage, variable speed equipment. They are hesitant to get caught replacing expensive parts.
02-04-2013, 01:47 PM #7
- Oct 2012
- 26
All great points. My only "issue" with it is from the layman's perspective (which I am). I know of Trane, American Standard, Carrier, York, Armstrong. I would look for brands like these that I know of. Once they re-brand (on their web site) they don't allow me to know what I am getting. Yes I can call and ask, but they should at least tell you what it really is on the web site to help people like me shop around easily.
02-04-2013, 01:52 PM #8
THe name of hte parent company is usually somewhere on the website. Or a simple wiki search should tell you who the mfg is.
But as mentioned above, other than certain features on high end equipment. The brand is irrlevant. Focus on finding a good contractor that will install it correctly.
02-04-2013, 01:57 PM #9
- May 2008
- Missouri
- 2,623
It is MUCH more important to find a good HVAC contracting business and build your loyalty with them than hoping to find what "brand" equipment is the best based on the amount of money the manufacturer spends on advertising. Frankly I've found an adverse relationship between advertising and quality of equipment in many cases!!
02-04-2013, 02:01 PM #10
- Oct 2012
- 26
Thanks! I have gathered that from discussing this in the past with you and have another thread to that end (see below link) but nobody has responded yet.....I'm hoping someone knows of these contractors and/or can support my approach.
http://hvac-talk.com/vbb/showthread....tractor-search
02-04-2013, 02:45 PM #11
Define rebranding? Not a lot of that done. Heat Controller using Nordyne equipment. Ingersoll-Rand's Ameristar using Midea outdoor units. There's some private label like R E Michel Airtemp & Broan or Winair using Nutone, both made by Nordyne. Otherwise it's pretty clear what's in each family. Carrier, ICP, Allied, York etc.
02-04-2013, 02:59 PM #12
- Oct 2012
- 26
local contractor sites and they are calling things "Ever-Rest" for example...or "Oliver"....they "rebrand" them with their own unique name.
02-04-2013, 03:10 PM #13
- May 2008
- Missouri
- 2,623
The only thing that is "rebranded" is the equipment outside sticker. The manufacturer's specification label is still there which gives the brand, model, and serial numbers so you'll quickly know who made the equipment. Not a big deal either way. IMO anyway.
