Results 1 to 7 of 7
    Oct 2011
    TX
    Round up Steamer issues
    Anyone work on these steamers and have issues with the spray tubes leaking and filling the steam chamber when off. Is there a replacement kit?
    Oct 2008
    mid-Tennessee
    Sean, they make nine different steamers. Sounds like a faulty solenoid valve. Call Roundup/A.J. Antunes @ 800-253-2991 for tech support and part numbers.
    Oct 2011
    TX
    It's a model DFW-150CF. I saw on the Internet that there migh be a kit using John guest fittings, seems like that would work better than the current setup. I don't believe there is a solenoid valve, there is a small pump. Maybe there is a diaphragm in the pump that is leaking by?
    Oct 2008
    mid-Tennessee
    Quote Originally Posted by SeanH View Post
    If you're wondering about any upgrades that AJ Antunes/Roundup may have available, you should call them. Sometimes a printed manual is dated and won't reflect such things.
    I've never worked on one of these steamers. However, I did perused their manual. You can go to http://www.partstown.com/ and use options in upper-right corner to "Find Equipment Manuals" and download yourself a PDF version of the Service & Parts Manual.
    Looks like it probably needs a water pump kit (pn: 7000850), which includes a tube kit with it. The parts breakdown doesn't show any rebuild kit for the pump.
    Make sure your customer hasn't lost the water tank filter assembly (pn: 0010159) and that they know to remove and clean it monthly per the manual. If it's missing, I suspect that would cause premature failure of the pump.
    Denver , Co.
    Check to see your water pressure is no more than 25 psi , if so they sell reg/filter kits that go with steamers
    Outlaw guns? only outlaws will have guns
    Those who live by the sword are SHOT by us who don't.
    Oct 2008
    mid-Tennessee
    Quote Originally Posted by IceVicious View Post
    You are correct regarding water pressure to a model DFW-250, where the "2" denotes direct water hookup. It uses a solenoid valve to control water flow. Incoming water pressure should be regulated to below 30 PSI. AJ Antunes/Roundup does sell a regulator kit for that application.
    However, Sean's steamer is model DFW-150, where the "1" denotes self-contained water tank, and uses a built-in pump to deliver the water to the steam chamber.
    Denver , Co.
    thanks for correcting me Sir
