Results 1 to 7 of 7
Thread: Round up Steamer issues
02-02-2013, 09:24 PM #1
- Oct 2011
- TX
- 81
Anyone work on these steamers and have issues with the spray tubes leaking and filling the steam chamber when off. Is there a replacement kit?
02-03-2013, 02:39 AM #2
- Oct 2008
- mid-Tennessee
- 260
Sean, they make nine different steamers. Sounds like a faulty solenoid valve. Call Roundup/A.J. Antunes @ 800-253-2991 for tech support and part numbers.
02-03-2013, 02:54 PM #3
- Oct 2011
- TX
- 81
It's a model DFW-150CF. I saw on the Internet that there migh be a kit using John guest fittings, seems like that would work better than the current setup. I don't believe there is a solenoid valve, there is a small pump. Maybe there is a diaphragm in the pump that is leaking by?
02-03-2013, 05:11 PM #4
- Oct 2008
- mid-Tennessee
- 260
If you're wondering about any upgrades that AJ Antunes/Roundup may have available, you should call them. Sometimes a printed manual is dated and won't reflect such things.
I've never worked on one of these steamers. However, I did perused their manual. You can go to http://www.partstown.com/ and use options in upper-right corner to "Find Equipment Manuals" and download yourself a PDF version of the Service & Parts Manual.
Looks like it probably needs a water pump kit (pn: 7000850), which includes a tube kit with it. The parts breakdown doesn't show any rebuild kit for the pump.
Make sure your customer hasn't lost the water tank filter assembly (pn: 0010159) and that they know to remove and clean it monthly per the manual. If it's missing, I suspect that would cause premature failure of the pump.
02-04-2013, 10:24 AM #5
Check to see your water pressure is no more than 25 psi , if so they sell reg/filter kits that go with steamers
Outlaw guns? only outlaws will have guns
Those who live by the sword are SHOT by us who don't.
02-04-2013, 12:30 PM #6
- Oct 2008
- mid-Tennessee
- 260
You are correct regarding water pressure to a model DFW-250, where the "2" denotes direct water hookup. It uses a solenoid valve to control water flow. Incoming water pressure should be regulated to below 30 PSI. AJ Antunes/Roundup does sell a regulator kit for that application.
However, Sean's steamer is model DFW-150, where the "1" denotes self-contained water tank, and uses a built-in pump to deliver the water to the steam chamber.
02-05-2013, 03:55 PM #7
thanks for correcting me Sir
