Results 1 to 9 of 9
    Sep 2010
    miami,fl.
    start cap blew up
    carrier infinity system thermostat said communication error lol i said oh man i hope its something obvious, im not familiar with these fancy t-stats.
    i jumped when i opened the condenser's electrical compartment because all the paper from the start cap dropped out. the start cap shot down and knocked off a male terminal comming off the circuit board. all the wires were burnt together.
    Southeastern Pa
    Okay.
    Do you have any guesses as to what would make a start cap blow apart.....?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Quote Originally Posted by timebuilder View Post
    Okay.
    Usually a fried potential relay, but a stuck compressor, cycling on its overload, can cause it too, among other things.
    Jun 2001
    Possibly a cap that the internal overload didn't activate properly?
    Looks like that stayed in the circuit a little long. Wish I could find one like this. Only have found them partially melted leaking fluid
    Sent from my SCH-I800 using Tapatalk 2
    May 2009
    Cumming, GA
    Quote Originally Posted by hvac wiz 79 View Post
    Haha. I don't wish to find one like this. That looks like a terrible mess to clean up.
    But, I would like to troubleshoot the reason for such a catastrophic failure
    Nov 2009
    Tennessee
    Okay.
    Back when I did refrigeration I had a condenser that was flooded from a rain storm that blew both run and start caps. The ribbon from the start cap was still hot when I came up on it. I remembered that for a long time. Not the kind of learning experience a person wants.
    Apr 2010
    East of Lyndon's
    Most likely your start relay is bad or the wire came off terminal #5. Usually if the cap blows up it's because the relay didn't open.
    If you can't fix it with a hammer, you've got an electrical problem.
    Sep 2010
    miami,fl.
    Okay.
    well a couple of reasons that i know are if the compressor is short cycling could be due to a few issues low pressure, hi pressure or any issue that causes the compressor to short cycle. also if the start cap is staying in the circuit too long due to bad start relay, or if the start cap doesnt have a bleed resistor. but if ive missed anything let me know. i always have my eyes and ears open for more knowledge
