Results 1 to 13 of 16
    Jan 2012
    Nj
    BacNet IP intergation to Metasys
    Hey all
    I am a first time poster. Has anyone out there integrated a Micro tech II controller to a NAE using BacNet IP before? The building I’m at used to have N30s and was recently upgraded to a NAE55. I found literature on how to setup BACnet® Controller Integration with NAENCE LIT-1201531. Still, I am having a problem with auto discovery not finding my devices. Unfortunately I do not have the micro techs ip addresses. On the other hand if I hook up the old N30 I can see the micro techs. So I know they still work and can communicate. Does anyone have any thoughts or suggestions?
    Nov 2005
    Shreveport, Louisiana
    Since you can see them in the N30 then get the ip addresses from the N30 and then manually insert it into a bacnet integration in the NAE...
    UA Local 141
    Jan 2012
    Nj
    I’m curious thou. If I enabled the NAE to work with BACnet networks set to true and ANSI x3.4 encoding, verified network address and port match I should be able to insert a field device and auto discover. Or maybe I missed something? It just seems strange the N30 still sees the micro techs and NAE doesn’t. As far as getting the addresses from the n30, I couldn’t find them when I hooked up to it….
    For some reason, it finds some and doesn't fine others! What you need to do, is run the auto discovery around 4 times. If it doesn't pick it up then, you need the IP address.
    Do you have Project Builder? if so, look in for the BBMD which contains the IP of the tech II - if they used it?
    To verify this works - you really need the IP address of the tech II so you can force the NAE to bind.
    Let us know what happens
    Jan 2012
    Nj
    Thanks for the info. I believe I have project builder somewhere. Ill post back with my results.
    Mar 2012
    Did you reboot the NAE after you enabled the site to be a Bacnet network?
    Apr 2010
    Ontario
    If this is the Micro tech 200 I don't believe it will work a back net card.
    Jan 2012
    Nj
    so i found project builder then it dawned on me i dont think i ever used it before. whats the best way to pull the info off the n30 and read it on project builder?
    Quote Originally Posted by Hate2obey View Post
    Do you have the database - it ends with a .mpb. If you do, just click on this and it will open the database.
    if not
    You need to open project builder and setup SiteBook. Then upload the database from the live N30.
    The object you're looking for in the N30 is BBMD
    Once you get the IP address of the tech - you need to add it into the NAE under Site - 3rd Party BBMD.
    Address - UDP 47808
    Address - xxxxxxxxx (enter in the IP address of the tech)
    IP Broadcast Mask - 255.255.255.255 (keep it all 255)
    If that doesn't work - we can use the back door to link the tech to the NAE.
    Let us know how you make out.
    Jan 2012
    Nj
    Quote Originally Posted by integrator View Post
    if not
    Address - UDP 47808
    So after playing around with my computer i finally got to upload my n30s databases into project builder. There is are no BBDM objects but there is programing containers for my mcquays. I can only assume the n30s were never fully programed to see them. Its possible originally the mcquays just ran off their internal schdules. i know they have bacnet ip cards, now i gotta find away to obtain there ip addresses i guess.
    Dec 2010
    Detroit Michigan
    Was the N30 on their network? If it was standalone maybe they just used the Microtech II default IP address. I had a job once and the ip address was 17216.83.1 . You could set your laptop up and try to ping the Microtech II to see if that is the default. Or google Mcquay and see what the default address is for that piece of equipment.
    Pa
    What Revision of Metasys are you dealing with?
    Jan 2012
    Nj
    Quote Originally Posted by dodger454 View Post
    Its revision 5.1.0.4400
