Results 1 to 9 of 9
    Oct 2006
    tx
    txv low sh low sc
    replaced a compressor #1 on a goodman package unit. M#PCB120-3. Unit has txv. After starting and running for 20 min i was getting these readings. comp#1 rla 18.6, 13.1, 13.4 , 14.3. Blwr rla 8.4, 6.2, 6.0, 5.7. CF rla 3.5 , #1,3.0,#2,2.8. pressures 52/160. S.L. temp 31. sh 3. L.L. temp 87. sc 0. amb 70. ra 73. sa 54. return air grill is clean, as is evap, blowr wheel, and cond. Motor pulley has been changed and is maxed out. im thinking txv stuck open., but wouldnt i have a higher suction pressure. txv bulb is attached properly to line. ran out of time store closed will return to finish tommorow. what do you guys think.
    Southeastern Pa
    Quote Originally Posted by ats890 View Post
    1) how did you charge the unit? Weigh in after a deep vacuum?
    2) where did you take the suction line temp?
    My first thought is that you have a heat transfer issue (low suction pressure, not enough heat getting into the refrigerant). In the case of a stuck open txv, it can be a case of more refrigerant than is needed for the available heat. After all, you do have 20 across the evap.
    A bad txv can be tested for by chilling and warming the bulb, and looking for changes in pressure. No change, bad txv. I'll trust that you DO know when a bulb is not correctly poitioned...
    It is possible that you found what killed the compressor, too.
    You did replace the dryer, right?
    You have enough posts for Pro. Get that done. I don't like to put this level of detail in the open forums.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2011
    Long Beach, CA
    I would first verify that you have correct air flow by verifying total static pressure across the coil and confirm that it meets manufactures data specs.
    What is the outside ambient temperature when taking readings.
    What is return air temperature.
    Do you have some form of head pressure control.
    I would raise the head pressure to somewhere in the range of 200 PSIG before looking for problems. This can be accomplished many ways or as suggested by manufacture for low ambient control.
    But I am still learning and looking for a new mentor.
    _______________________
    In a strict sense troubleshooting is not part of the repair..........understand the symptoms and you will find a solution.
    Oct 2006
    tx
    I took suction temp at compressor . I did change drier . System failed acid test . I added suction drier and acid away. I pulled deep vacuum. My static pressure was 0.3 total. 0.17 supply. 0.14 return. Txv bulb placed at ten oclock. I will try warming bulb.
    Oct 2006
    tx
    I weighed in charge per nameplate. I will sign up for pro membrship.
    Southeastern Pa
    Quote Originally Posted by alcomech View Post
    I have used a tarp and cardboard to artificially raise head pressure.
    We install low ambient when the cust is willing to pay for it. Not all will.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2011
    Long Beach, CA
    Is that a twenty ton unit with 2-ten ton compressors?
    If thats the case it looks like you are not moving enough air. But you will need to cross reference with the data sheet.
    What size is the duct work for the return.
    What size is the supply duct.
    Is this a constant volume system.
    What is the space temperature which you are trying to maintain.
    Jan 2005
    Emerald Coast
    OAT 70*.
    Bulb @ 10 o'clock, hmmm.
    Do not attempt vast projects with
    half vast experience and ideas.
    Feb 2013
    Soon I will be in NE
    I think the airflow guys are onto something
