Results 1 to 10 of 10
    Trane CHHP Screw Compressor Service Manuel
    Hi,
    Can anyone help me in downloading Trane CHHP Screw Compressor Service Manuel. I want to know how to remove the bearing housing of the compressor. Please help.
    Oct 2006
    Central Texas
    There are troubleshooting guides, as far as a service manual for teardowns... to my knowledge Trane does not put out a manual, in other words they don't want you to take the compressor apart for rebuild. It's not that it can't be done, I've never done it, there maybe a compressor rebuild shop in your area that knows how. Definetly not something to try in the field. CHHP is this on an RTAC? Out of curiosity why do want to remove the bearing housing?
    Sic Semper Tyrannis.
    Not sure what your planning on doing but as txhvac said, chhp compressors, as well as most screws are not rebuildable in the field.
    Jun 2007
    need help with a Trane CHHP Screw Compressor
    I am looking for a manual for a CHHP compressor. I am looking for a check out procedure for the slide vale operation. I have a compressor that will not load or unload.
    Jun 2009
    Florida
    RTAC-SVD02A-EN is the publication number you need so you'll know what to ask for when you go into your local Trane office.
    Low Pressure Forever!
    If you know heavy metal, you can work anywhere-Dave Andreson
    Anchors Aweigh my boys, Anchors Aweigh!
    Farewell to foreign shores, We sail at break of day. Through our last night on shore, Drink to the foam. Until we meet once more. Here's wishing you a happy voyage home!
    Jun 2007
    Thanks for the info. My local supply house is e mailing me the doc.
    Santo Domingo,Dominican Republic
    elldog64,I know is been a long time but do you still keep that doc. on the trane screw comp? I would like to have too if you may, Thanks My email is on profile
    ChillerWisperer
    Do you by any chance still have an electronic copy of the document you mentioned?
    Hey jpsmith1cm
    The answer to my request is:
    http://hvac-talk.com/vbb/showthread....ane-RTAC/page3
    Thanks, I think you can lock this one!
