Page 5 of 7 FirstFirst 1234567 LastLast
Results 53 to 65 of 82
  1. #53
    Home of the newly wed and the nearly dead
    Direct drive, 180-390 tons.
    Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
    "It's called the american dream because you have to be asleep to believe it" -George Carlin
    "A nation of sheep begets a government of wolves" -Edward R. Murrow
    "I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
    Buy american made goods & support locally owned businesses!
  2. #54
    ottawa canada
    Quote Originally Posted by Tech Rob View Post
    Ditto ... low pressure to .
    Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
  3. #55
    The Heart of It All
    was in la crosse and was told they are direct drive so no gears. also was told one needs to becareful with wrenches around the motor because the magnets have a 500 lb pull and could be bad for the fingers.
  4. #56
    Quote Originally Posted by desto1 View Post
    So I guess we'll all need to get some stainless steel wrenches and aluminum sockets!
  5. #57
    Aug 2009
    Prattville,Alabama
    I have heard that it is low speed, and will use R123, but is compatible for the new refrigerant (R245fa?).
  6. #58
    May 2009
    Calgary AB
    Looks like a bench grinder with a paint job, is it same old trane junk that you've gotta glue together with loctite?
  7. #59
    Not in Iran
    Ouch Arron!
    This is will interesting to see what happens in the future though, I believe this is the first oil free machine that Trane has developed, . The oil free seems to becoming more common in the centrifugal market, Trane needed and did come out with the oil free system to compete in the oil free market. And I love the small footprint !!!
    Only available in the 200 to 400 ton range as of now.
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
  8. #60
    May 2009
    Calgary AB
    By the time this unit hits the market the oil free will be a thing of the past
  9. #61
    Jan 2011
    Quote Originally Posted by aaron604 View Post
    Doubt it.
  10. #62
    May 2009
    Calgary AB
    Quote Originally Posted by KnewYork View Post
    Doubt it.
    Youre right, I'm being sarcastic. Just pointing out that Trane seems to be taking forever to put out a modern machine is all.
  11. #63
    Their R&D does move at a glacial pace. I'd rather that than have them rush some P.O.S. to the market so they can say "Me too".
  12. #64
    May 2009
    Calgary AB
    I still get the feeling their equipment is engineered by 4 year old students from Nepal that are being told to "do math". I just don't have a lot of patience for machines that use loctite as gaskets and expect you to use a clear plastic hose to check refrigerant level in the evap.
  13. #65
    I think the simplicity of Trane's design is genius. Eventually, if you're around them enough, everything else begins to look like an over-engineered and over-controlled P.O.S. We all know, however, that there's at least one thing that every manufacturer got right with their machines that the other guys got wrong.
    What do you have against using a clear hose to see where the refrigerant is at? You can use this method on almost any flooded chiller. It's especially useful if you just weighed the charge in and want to mark it for the future. Besides, it's only one of the things that we can use to determine charge levels. It's not like you're going to go straight to checking the level while ignoring the water temps, evap. approach, vane position, motor current, etc. Is it easier to hook up a clear hose or to recover and weigh the charge?
