Results 1 to 13 of 38
    Ypsi. Mi.
    lennox pulse furnace
    Anyone ever replace the 3/4 hp blower in the g/14q.Lennox say`s I have to buy there's it`s heavy duty and any other 3/4 hp motor will fail fast.Well the motor they sell is close to 350.00 and they don`t have one here close.It`s fricking cold out here in Ann Arbor.My normal supply house has a 3/4 hp motor and cap for under 200.00 that will fit lennox mounting bracket.
    Jul 2010
    nebraska
    Pressure tested the heat exchanger yet? No sense sticking a motor in if the heat exchanger fails inspection.
    burlington county n.j.
    yes it's expensive, others will fail.
    remove your pricing and pressure test the hx.
    Ypsi. Mi.
    Quote Originally Posted by t527ed View Post
    i got a ao smith motor it has no white wire or neutral wire.So what wire do I use for common.
    May 2011
    Ripley, WV
    The wire designations should be listed on the tag on the motor body. What is the motor part number?
    Apr 2012
    Yellow is usually common if no white.
    Nov 2001
    east kansas
    Replacement motor will probably fail soon. I'd do OEM only.
    BTW, did the furnace pass the pressure test?
    Beware of advice given by some guy on the Internet.
    Jan 2013
    The Cheese State
    Id replace the whole furnace parts becoming mor and more obsolete be much better in Long run to replace. Great rebates to replace!
    Sent from my HTC Hero S using Tapatalk 2
    Oct 2005
    Pacific Northwest
    Quote Originally Posted by JAYLUPARK View Post
    Um that's probably incorrect. I Hate to see a smoked motor.
    Sep 2003
    AO Smith has some Blower Motors that have a yellow wire as common
    Also they sometimes use purple and of course white
    I have seen the statement "... yellow/white for common..."
    But as stated, there should be a reference on the motor itself!!
    Oct 2011
    Toronto
    Agree with changing the furnace, once you have to change out a spark plug youll be wishing you had
    Nov 2008
    Bristol Va.
    Quote Originally Posted by GastecD View Post
    I can change out the flame sensor and spark plug in less than 5 minutes. that is being at the furnace it has cooled down & the little panel already off. There are easy ways to do a lot of jobs you just have to think outside of the box.
    dogboy
