Results 1 to 10 of 10
    Jan 2013
    What is a permanently closed window
    Venting instructions say that it must be 4' from a window that may open, and 1' from a permanently closed window. That is difficult because my windows are closer than 8' apart. Can I put a screw through a double hung window and make it permanently closed?
    Jun 2006
    Richmond, VA
    permanently closed windows can NEVER be opened by design.....no screws ....
    "Decidedly Superior in a twisted pathetic way".....
    south louisiana
    what is it you are venting?
    by code ...beshvac is right.
    because by removing the screw the window isn't permanently closed.
    best of luck
    SW FL
    It's the one with The Duct Tape !.. L.O.L.
    Designer Dan
    SW FL
    double
    Designer Dan
    Southeastern Pa
    A permanently closed window is what you'd find downtown in an office building. It's designed to be looked out of, but not opened.
    May 2008
    Missouri
    i'm pretty sure glass block windows will qualify as "permanently closed" since they can't be opened. But also sure you can't temporarily screw a window shut and get the inspector to agree to "permanently closed" status. Find another way such as calling an experienced professional!
    Fort Worth, TX
    I think a similar term is "non-operable" window. But it could also give someone the notion that they could run a screw into the frame and call an otherwise operable window "non-operable". Nope. "Non-operable" or "permanently closed" means that is how the window is MADE, not what it can be modified TO.
    Psychrometrics: the very foundation of HVAC. A comfort troubleshooter's best friend.
    south louisiana
    what are you venting?
    Cincinnati, Oh
    Ditto on the above guys, especially energy rater.
    The rule you list is generally related to non-direct venting.
    If your equipment is able to be direct vented, I would suggest it.
    Especially since direct venting should VASTLY change the venting clearances.
    "Just get it done son."
    Dad adjusted
