    Jan 2013
    Rheem help needed
    Imperial 80 plus. Model rgde-12rajs. It's an old unit. Unit fires and turns off. After running 3 cycles it shuts off and does not fire. The fan also stays on when no heat commands are given even when the thermostat is unwired. Any ideas ?
    Must add I did get it to run for a few hours but after reaching the thermostat temp is shut off and has not run properly since.
    Generic awnser: Call repair company and pay for service call.
    For real awnser: You can get hurt working on your own furnace.
    Houston,Tx.
    Thats got to be late 80's or early 90's, I would have the thing checked for cracked heat exchanger before I would spend any money on it.
    Jan 2013
    Had a repair guy come already. After 20 min he got frustrated and told me the whole unit was shot. He also took my surface igniter with him.
    Alabama
    Quote Originally Posted by Demoiod View Post
    My guess would be that he is correct. Sounds like cracked HX. Time to replace.
