Results 1 to 13 of 27
    Seems like changing my thermostart killed my air A/C
    Hi Folk,s
    I hope 2013 has started well for everyone. I myself am blessed but ran into a real challenge today.
    Let me start at the beginning:
    I noticed over the last two months(Nov and Dec 2012) that my electric bill doubled. On inspection I noticed that the outside part of my unit (compressor and condenser) were not activating. I called AHS who sent out a contractor.
    He told me that my thermostat was not made to handle two heaters I had a (one cold and 1 hot type thermostat).
    He said I was using the electric heaters in my air handler hence the reason for the large electric bill. I needed a Thermostat that would drive both the outiside heat pump and the inside electric head coils.
    I went to Home Depot and bought a Honeywell RTH2510/RTH2410 thermostat and successfully(or so I thought) installed it.
    At first I activated my fan that comes with the air handler and also my outside unit. After 3 minutes or so I decided to trying cooling to see if that works (its about 70 F here today) and walked away. I hear a sort of humming and started to smell burnt electrical smells. The unit went dead before I could turn it off.
    Now my unit(inside and out) will not activate at all. Nothing!
    Specs:
    Inside unit:
    Manufactorer: RUUD
    MOdel: UHQA-0805BDH
    SN# : H M1689 5823
    Outside UNIT:
    Manufactorer: Unitary Products
    MOdel: XTH0124BA
    SN#: EKBM355920.
    I really believe I burnt out the control circuit or something.
    Does anyone here have insight or suggestions on what I could/should do?
    Thanks,
    T
    Anderson SC
    I would call for service and not AHS or any home warranty service contractor. You fried it.
    Mount Airy, MD
    That's all I got besides call a pro
    Well its a pretty old system so I am not really sure who to call. AT this point I would like options. I would like to understand what the tonage and other specs are for the system cuss maybe I can get a used one or something Or replace the system for relativity cheap. But I would like options.
    Anderson SC
    Quote Originally Posted by techie768 View Post
    Used equipment is not a good idea, lots of times it doesn't work and you'll have trouble finding someone competent to install it. It almost always ends up costing you twice to have a pro cone behind and install a new system.
    Anderson SC
    Post the model number of the indoor and outdoor unit and we can tell you tonnage etc.
    Mount Airy, MD
    There is about a 99.9% chance that you just cost yourself more money then calling in a professional in the 1st place.
    There is a contractors locators map on this site and it might be best that you contact one of them that is in your area.
    Thanks Chris...that's pretty helpful. I didn't deduce that!
    Jtrammel I did post the specs...the model and serial numbers for both parts of the unit.
    Thanks.
    Anderson SC
    Sorry, its a york/coleman 2 ton 10 seer heat pump
    Anderson SC
    And the indoor looks to be a 2 ton 14 seer air handler which would be fairly new?
    Truly,
    I dont mind hiring someone to do fix/change out this unit. I will have to...both units are pretty old.
    I just wish to find professionals that are honest.
    I have found finding the honest one amongst the rest can be difficult and costly.
    recently this mechanic wanted to charge me $700.00 to change two sensors in my car when only one was bad it was changed out for
    $200.00. Everywhere I turn in America it seems that the prevailing mentality is "lets fleece the clients." That is pretty discouraging.
    Anyways, I will shop around and do some research and find someone to do something about this HVAC.
    Thanks folk. I appreciate your assistance.
    Happy 2013
    Jtrammel,
    I thoguht the inside unit was A RUUD and the outside unit was from Unitary products. That is what is on the label. How do come about with York/Colemen.
    They aren't old?
    Mount Airy, MD
    Thanks.
    The wifey is pretty pissed off at you right now isn't she?
    No worries these guys will get you back on track !
    Good luck to you !
