Page 2 of 8 FirstFirst 12345678 LastLast
Results 14 to 26 of 97
    Jan 2013
    San Gabriel Valley, California
    Quote Originally Posted by jayguy View Post
    what? your calculation? you said the nameplate was 3 lbs. you said you think 6 lbs is the proper charge in your original post.
    perhaps you should post a step by step process in how to understand a nameplate.
    i do not think that 'newbie' describes you properly.
    Dude, u try to mess with me or what? I didn't say I think 6lb is proper charge. I said that 6 lbs is a proper charge. That was what I meant. And the manufacture name plate states charge about 1.36 kilogram which is 3 3lbs.. Am I clear now.. I think u should go to hospital to check your brain
    Dec 2012
    Spokane, Washington
    Quote Originally Posted by fengshvac View Post
    No fear of heights...man, this is gonna hurt!
    Dec 2012
    Spokane, Washington
    Prov 16:18
    Jan 2013
    Quote Originally Posted by Helioson View Post
    Prov 16:18
    Thx helioson, my brother.. Sorry for the pride.. My bad... I should talk more friendly..
    Southeastern Pa
    Prov 16:18
    Amen.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2009
    Mid-Mo
    Feng, you probably shouldn't piss off the help. You might need jayguy sometime.....
    Jan 2013
    Yeah, I know.. Sorry jayguy..
    did I miss the part where/how you determined the mfg was wrong?
    aside from you just dumped 6# of refer into a piece of equipment that was labeled for (3.3#)
    Nice gauges feng.
    Feng did you zero out scale after recovering freon. 3 plus 3 =6 HAHAHAHAHAHAHa.
    SE Michigan
    "I think u should go to hospital to check your brain"
    No this is some funny sheit! lmao!
    Oct 2011
    Chicagoland Area
    http://youtu.be/DKJsSPATDLY
    EDIT there is adult language in this video in case you are offended easily
    Jan 2013
    Quote Originally Posted by dandyme View Post
    I am very sorry bro, I can't teach you the charging troubleshooting skill in open forum.
    don't try to flatter your ego, just answer the question!
    dumping refrigerant into a system until the pressure/temperature is where you deem it necessary is in no way the intelligent procedure for determining the mfg put wrong data on plate.
