Page 1 of 8 12345678 LastLast
Results 1 to 13 of 97
    Jan 2013
    San Gabriel Valley, California
    Cool FengsHVAC a Professional HVAC Tech teach you how to fix Ice Cream Unit from Turkey
    Problem: the ice cream unit is not cooling.
    Insight: compressor was running, but the temperature was reading about 45 degree, and the evaporator fans were not running, sightglass bubbled.
    Solution: there was a leak at the king valve, fixed the leak. I charged the unit about 6LBS of R404a, while the manufacture name plate states 3LBS only. They made a mistake, I charged by superheat and subcooling. when I put in 5LBS, it was still low, so I had to put in 6LBS to make it cool properly. This unit was from Turkey. Hahaha. It's working fine now. The picture show 18 degree, but it drop down to -5 degree at setpoint...
Size:  41.1 KBName:  309923_119014908275915_1015513184_n.jpg
Size:  49.5 KBName:  419691_119014938275912_1818285143_n.jpg
Size:  44.1 KBName:  536911_119014964942576_4520843_n.jpg
Size:  25.3 KBName:  552900_119014994942573_389619264_n.jpg
Size:  41.3 KBName:  535409_119015014942571_1249450878_n.jpg
    Good job fengshvac, way to get er done! Those crazy Turkish can't even count hahahahaha gah!
    Jan 2013
    California
    I think people are happy you're back seeing from this and another thread.
    Tallahassee, FL
    after about 3lbs did it put it about where you found it before you "fix" the leak?
    Quote Originally Posted by fengshvac View Post
    ...I charged the unit about 6LBS of R404a, while the manufacture name plate states 3LBS only. They made a mistake, I charged by superheat and subcooling. when I put in 5LBS, it was still low, so I had to put in 6LBS to make it cool properly...
    3 kg (kilograms) is the same as 6.6 pounds...seeing how it was from europe, i would think that all nameplate data would be in metric units...so perhaps they did not make a mistake.
    Jan 2013
    Quote Originally Posted by jayguy View Post
    hey, u think i am a newbie?? jayguy?? a good hvac tech should never guess the problem.... 3lbs is after my calculation...
    what? your calculation? you said the nameplate was 3 lbs. you said you think 6 lbs is the proper charge in your original post.
    perhaps you should post a step by step process in how to understand a nameplate.
    i do not think that 'newbie' describes you properly.
    May 2011
    Western, KY
    Feng you're still posting these step by step things in an open forum. The tech to tech is open to everyone and this should be kept in the "pro" forums.
    Jan 2013
    Quote Originally Posted by mason View Post
    no, this is not step by step... is it???
    Oct 2011
    Chicagoland Area
    Feng, It's to avoid "do it yourself" Keep things vague in the open forums. If you get into the pro forum you can give all the help you want. Did you apply yet? you have enough posts.
    Jan 2013
    Crap... alright... then.....
    Oct 2011
    Chicagoland Area
    Feng, here is the link for pro membership
    http://hvac-talk.com/vbb/showthread....nal-Membership
    up in the hizzy
    thank you feng for teach me how to fix my frozen turkey , keep them coming
