Entouch Pro
Residential and Commercial applications
Technical Specifications
- Built in PIR Motion Sensor for Occupancy
- 7 Day Occupancy scheduling
- WiFi Networking
- Full Color Touchscreen Display
- Remote Web Portal Control
- Customer and Manager Apps
HVAC System Compatibility
- Supports gas / electric / heat pump systems
- Supports fan, 2 stage cooling, and 2 stage heat
- Support for auxiliary heat
- Configurable remote sensor input S1
Internet Communication
- 802.11 (b, g, & n)
- Supports DHCP and static connections
Power Requirements
- 24VAC: requires both R and C wires
- Dimensions: 3 x 4.75 x 1
Sensors that you can use 10K Type 1, 2 or 3 or 20K Type 4 sensors. This mean the sensor already installed can be used.
Fan Failure to send E-mail setup info
Put a current switch on the fan power wire and then wired the current switch output to our L terminal on the EnTouch. Then set the L input to be an alarm setting with a normally closed contact (contact is based on the switch used). Then they set it up in the portal to send out an email.
