Results 1 to 13 of 25
Thread: Trane HP quote
    Jun 2011
    SW Ohio
    Trane HP quote
    I recently had a quote given to me for a Trane HP and gas furnace to be installed. I had the company come out after talking to them at a local home improvement show and the rep said they did load calculations on all their quotes. The gentalmen did not do one when he was at my house but said he could have another guy come by to talk to me about it (still waiting on a call from him a week later).
    I was quoted a XV95 furnace and two HP's (XR16i,XR15). They would throw in a humidifier and whatever the lowest tstat trane has.
    After doing some reading on Trane it looks as if the XR16I isn't that great at dehumidifing. Other than the obvious of lower seer numbers should I get quotes on the XB14 and XR13? All of them would be better than our current system and not looking for the most energy efficent unit.
    I asked about the unit(s) he quoted being able to do "dehumidify on demand" through the tstat but he made it out like it would be allot of work. Is this true because I thought the tcon803 or Vision IQA can do that?
    I didn't get it quoted but is Tranes Cleaneffect filter system that much better than a good media cabinet type? I'm sure the cost is more so is it worth the extra $$ if w don't have allergies ect?
    IAQ control will do DOD if you don't get the 16 2 stage. It will also stage the gas backup. 802 won't do either.
    Sent from my HTC VLE_U using Tapatalk 2
    Jun 2011
    SW Ohio
    Sorry, it should be a XL16I not a XR16I.
    803 will overcool to drop humidity but not DOD.
    Aug 2010
    West Monroe, LA
    Quote Originally Posted by rk05 View Post
    What size system? Trane 803 t-stat would be my recommendation as a base model t-stat thatwill handler all the above. While agree that the 803 will only over cool to help with humdity control other then that very good t-stat.
    Jun 2011
    SW Ohio
    On the 803, so if we had the tstat set to 77 and the humidity was high it would cool the house to say 74 to drop the humidity?
    Would a seperate humidity meter be needed to run with the 803?
    I'm leaning towards the IAQ unless it wouldn't be needed.
    Jun 2011
    SW Ohio
    It's to replace a 80K furnace and 3ton AC.
    If you are putting in an XV95 backing a heat pump, the IAQ will properly stage the gas backup. The 803 will not, you would have to use the timer which means timing to high just when the house is warming up. Dumb. If the house is substantially humid, the 803 will overcool up to 3°. If a bit humid, it may only overcool 1°. The IAQ will dehumidify on demand which is slowing the blower if the humidity is high. That greatly skews the cooling towards latent, humidity removal. That feature isn't available if you use the 16i 2 stage, only with the single stage or 20i.
    Jun 2011
    SW Ohio
    Baldloonie, The 16i and 20i are both out for my options for HP. I don't think I will see my return for the price of both units along with the 16i not getting favorable revews.
    Thats also why I asked if I should be looking at the XB14 and XR13. If I go with a Trane it will be the XV95 two stage, VS system to take advatage of the VS blower for humidity.
    Your in the same climate as me, not sure if you install Trane or not but what do you think of the XV95 pared with either the XR15, XB14 or XR13 and using the IAQ for the humidity on demand feature?
    Oct 2010
    If you are in a primarily heating climate the the 13 or 14 seer ac with a variable speed furnace and IAQ stat would be your best value.
    Jun 2011
    SW Ohio
    I would say we are almost on an even split between heating and cooling months. Although, we can get pretty humid during the cooling season which is why I'm curious about the DOD feature.
    Aug 2010
    West Monroe, LA
    I would look at either the XB 14 or the XR 15 with the XV 95 furnace. Either way with a 3 ton coil and furnace 17.5 wide should yeild you 14.50 seer and 95 % effienct furnace.
    Many matches with the XR13 and XV95 will give you 14 SEER and 9 HSPF, some good numbers. The XB14 gains little in efficiency. The XR15 may gain you .5 SEER in a 3 ton and 17" furnace but the price premium for 1/2 a SEER point makes it a lousy investment. Spend $XXX to save $X. Another good control is Aprilaire's 8910 control. Less bucks than a VP IAQ and does a bit more.
    http://www.aprilairecontractor.com/home-comfort-control
